Move Apps between Datasets without losing data
Is there any way to move the apps and data to another Datasets without loosing the app configuration.?
Please help
Truenas Scale
Its like an organ transplant… you would need to be a surgeon and the instructions depend on the specific organ (app).
I’d recommend you are very specific about the problem description
Or just set-up another instance of the App on a new dataset.
I have next cloud aap installed on a an appnpool, now i want to move that app to another pool…
Pleases do reply if you have a perfect solutions…
I under the complexities and no need of extra knowledge base for understanding it deeper…
Thank you
