Need help with HHD Enclosure for ZFS Raid
I have ORICO-9958C3 connected via USB with 4 x 4TB WD Pro. Trying to run a RAIDZ1/Mirror Pool but only one drive is detected by the Server. Need help with a fix or recommendation for HDD Enclosure that is compatible with ZFS and that reads the hard drives separately.
I get this error message:
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 515, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 560, in _run_body
rv = await self.method(*args)
File “/usr/lib/python3/dist-packages/middlewared/service/crud_service.py”, line 287, in nf
rv = await func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 48, in nf
res = await f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 174, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool
/pool.py", line 574, in do_create
disks, vdevs = await self.process_topology(‘pool_create’, data)
/pool.py", line 268, in _process_topology
verrors.check()
File “/usr/lib/python3/dist-packages/middlewared/service_exception.py”, line 72, in check
raise self
middlewared.service_exception.ValidationErrors: [EINVAL] pool_create.topology: The following disks were not found in system: sdb.
The links are dead, but the products are still available.
