Newbie-problem: How to run skripts / command line instructions
I may have overlooked that I get any output after the smart tests have been finished?
I will check the log files to get further information.
No output. smartctl -t reports the expected time of completion upon initiating the test, it’s up to you to come back after and read the report from smartctl -a or -x.
I would like to repeat my question regarding the output message of the command sudo ./disk-burnin.sh -tm 'sda sdb sdc sdd':
0: 1 windows (created Tue Nov 19 09:56:45 2024)
1: 1 windows (created Tue Nov 19 09:56:45 2024)
2: 1 windows (created Tue Nov 19 09:56:45 2024)
3: 1 windows (created Tue Nov 19 09:56:45 2024)
Having used -tm in the command above, I understood that tmux would be active, but there are no separate windows, only the prompt $.
If typing tmux 1s in order to find out more details, I only got the following error message:
error connecting to /tmp/tmux-950/default (No such file or directory)
What am I doing wrong?
You launched the script using sudo, the tmux instances are likely running as root. Try using sudo tmux ls.
My NAS performed the various tests now successfully. The tests took nearly six days in total for all four 12 TB hard disks. The temperatures ranged between 35 and 37°C during the tests, in idle mode, temperatures range between 27° and 28°C.
I checked the results and found no bad sectors according the description in here: https://github.com/dak180/disk-burnin-and-testing/tree/topic/burnin
So I now assume that the hard disks are OK.
Thanks again to everyone here who has helped me with their advice. :smile:
