HI,
I tried deploy Nextcloud AIO in TrueNAS Scale 25.10 with “Install via YAML”, it’s fonctional but GPU is not detected.
My conf :
services:
nextcloud-aio-mastercontainer:
image: Package all-in-one · GitHub
init: true
restart: always
container_name: nextcloud-aio-mastercontainer
volumes:
nextcloud_aio_mastercontainer:/mnt/docker-aio-config
/var/run/docker.sock:/var/run/docker.sock:ro
network_mode: bridge
ports:
8080:8080
deploy:
resources:
reservations:
devices:
capabilities:
gpu
driver: nvidia
count: 1
environment:
APACHE_PORT: 11000
NEXTCLOUD_ENABLE_DRI_DEVICE: true
NEXTCLOUD_ENABLE_NVIDIA_GPU: true
NVIDIA_DRIVER_CAPABILITIES: all
NVIDIA_VISIBLE_DEVICES: void
volumes:
LarsR
February 12, 2026, 11:43am
What’s your GPU? The driver that 25.10 uses depreciates a lot of old gpus. Anything older then a 16XX card doesn’t work anymore
It’s Nvidia T400 and after Nvidia A400
Last version YAML :
services:
image: ghcr.io/nextcloud-releases/all-in-one:latest
init: true
restart: always
volumes:
- nextcloud_aio_mastercontainer:/mnt/docker-aio-config
- /var/run/docker.sock:/var/run/docker.sock:ro
ports:
- 8080:8080
deploy:
resources:
reservations:
devices:
- capabilities:
- gpu
driver: nvidia
count: 1
environment:
APACHE_PORT: 11000
volumes:
LarsR
February 12, 2026, 2:18pm
5
OK the T400 is supported by the driver.
Did you tick the install nvidia driver in the settings for the apps system?
Did you check from shell with nvidia-smi if truenas sees your gpu?
truenas_admin@truenas[~]$ nvidia-smi
Thu Feb 12 15:26:59 2026
| NVIDIA-SMI 570.172.08 Driver Version: 570.172.08 CUDA Version: 12.8 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA T400 Off | 00000000:17:00.0 Off | N/A |
| 38% 27C P8 N/A / 31W | 3MiB / 2048MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
And
truenas_admin@truenas[~]$ sudo docker exec --user www-data -it nextcloud-aio-nextcloud nvidia-smi
[sudo] password for truenas_admin:
exec /usr/bin/nvidia-smi: no such file or directory
truenas_admin@truenas[~]$ sudo docker exec --user www-data -it nextcloud-aio-mastercontainer nvidia-smi
LarsR
February 12, 2026, 3:09pm
7
you didn’t specify the nvidia runtime in your yaml (i added it).
services:
runtime: nvidia # <---- was missing
init: true
restart: always
volumes:
ports:
- 8080:8080
deploy:
resources:
reservations:
devices:
- capabilities:
- gpu
driver: nvidia
count: 1
environment:
APACHE_PORT: 11000
volumes:
LarsR:
runtime: nvidia
And in this website but not functional How to Specify NVIDIA Runtime in docker-compose.yml for TensorFlow GPU Containers — codestudy.net
services:
runtime: nvidia
init: true
restart: always
volumes:
ports:
- 8080:8080
deploy:
resources:
reservations:
devices:
- capabilities:
- gpu
driver: nvidia
count: 1
environment:
APACHE_PORT: 11000
NVIDIA_VISIBLE_DEVICES=all
volumes:
````truenas_admin@truenas[~]$ sudo nvidia-container-cli --load-kmods info
NVRM version: 570.172.08
CUDA version: 12.8
Device Index: 0
Device Minor: 0
Model: NVIDIA T400
Brand: QuadroRTX
GPU UUID: GPU-5418fb24-4219-12b3-8d20-cbbfd6de0336
Bus Location: 00000000:17:00.0
Architecture: 7.5
truenas_admin@truenas[~]$`
Hi, i think it’s ok
sudo docker exec --user www-data -it nextcloud-aio-memories nvidia-smi
Mon Feb 16 12:11:38 2026
| | | MIG M. |
| 38% 33C P8 N/A / 31W | 3MiB / 2048MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
With this config:
services:
runtime: nvidia
init: true
restart: always
volumes:
ports:
- 8080:8080
deploy:
resources:
limits:
cpus: '4'
memory: 4096M
reservations:
devices:
- capabilities:
- gpu
device_ids:
- GPU-5418fb24-4219-12b3-8d20-cbbfd6de0336
driver: nvidia
environment:
APACHE_PORT: 11000
NEXTCLOUD_DATADIR: /mnt/DATA/UserDATA
NVIDIA_VISIBLE_DEVICES: GPU-5418fb24-4219-12b3-8d20-cbbfd6de0336
networks: {}
group_add:
- 44
- 107
- 568
volumes:
x-portals:
- host: 0.0.0.0
path: /
port: 8080
scheme: https
