"No Applications Installed" Issue
Running Community Edition, most up-to-date 25.10.3.1. I have a fairly small SSD as my apps pool device (Pool_1), and this morning it was at 99% capacity. The apps were all showing normally at this time, most of them running.
I went to delete Pool_1 snapshots to free up space. This is something I have done countless times and never had an issue. I deleted the snapshots and everything seemed normal. There is marginally more available space on the pool, however it is still quite full. The problem is, on the “Apps” tab, none of them are showing up now. It says “No Applications Installed…” “Click below and browse available apps to get started.” The Apps service is still running. The apps, themselves, are somehow still running, as I can access their services!
How can I get them to show back up in the Apps tab?
Have you tried switching it off and on again? I mean rebooted, of course.
Unfortunately I was fairly dumb and tried to unset the pool and re-set it before I rebooted. It was fairly dumb because I was remote-ing in using a VPN running on the app pool I had just unset. Dumb. So, I’ll have to wait until this afternoon when I can get home to troubleshoot further.
I’m having the exact same issue, rebooting did not work. It solved the issue before, not now though. Any luck on your side fixing this?
Edit: This fixed it for me:”
i Got it fixed by installing a random app (in my case Vikunja) from the Apps Section, that seemed to force the docker stack to properly refresh and all my apps were there again. Delete the random App, everything as good as new!”
Thanks N20VSLS
Yes, some combination of unset/set pool and rebooting the machine worked. So… my problem is resolved.
