I have upgrade my TrueNAS scale without problem from 25.04 to 25.10.
I only lost one important feature : the HDD spindown.
I have six 7200 HDD SATA disk, with only a NFS share on it. Means, nothing at all regarding ix app, logs etc.
If I boot the TrueNAS without network cable plugged in it, HDD never spindown even after several hours.
When I send the 6 commands “hdparm -S 120 /dev/sdX“ from console, I have the 6 HDD spinning down as it should 10 minutes after. Then, even if I connect back the network, no spinup if I do not access to the NFS share for several hours. If I do an access to the NFS share, file is served, then the HDD spindown after 10 minutes, as it should.
If I go on each disk setup on TrueNAS menu, everything is correctly setup, means “1” for the most aggressive APM setting, and the 10 minutes setting is selected.
I conclude TrueNAS doesn’t send any-more the spindown timer setting, I need to set it by hand after each reboot, but how could I check it?
How can I activate logs, or maybe I’ve miss something in the setup of this new 25.10 ?
(I run last version : 25.10.3.1 - Goldeye, and see in the release notes some major change in smart stuff)
Cheers,
