Permission denied on container disk
I have an Ubuntu installation in an Incus container that I use to update my IP address with my ISP, IONOS (DynDNS).
It works fine.
I would like to back up data from this Ubuntu installation to a dataset.
I mapped a dataset “/mnt/DisqueB/ubuntu” to a directory “/mnt/ubuntu” by creating a disk using the graphical interface:
When I try to access “/mnt/ubuntu”, I get a “Permission denied” message.
The dataset permissions are listed below:
Thank you in advance for your help.
You need to grant access to the truenas unprivileged container root user. There is documentation for this. You also will need to grant access to potentially other users / groups in the container. There is documentation for this as well.
Done. It works. Very simple once you know how. :slightly_smiling_face:
Merci.
