PiHole - port 53 appears to be conflicting
Hi All,
I’ve been running my TrueNAS Scale instance for a few weeks without issue. After a powercut yesterday, all the apps came back up, apart from Pihole.
After looking into the /var/log/app_lifecycle.log for more details as advised, I found this.
11.12MB/11.12MB
9fe644bd1a92 Pull complete
pihole Pulled
Network ix-pihole_default  Creating
Network ix-pihole_default  Created
Container ix-pihole-pihole-1  Creating
Container ix-pihole-pihole-1  Created
Container ix-pihole-pihole-1  Starting
Error response from daemon: driver failed programming external connectivity on endpoint ix-pihole-pihole-1 (18a41e823f3a49e29c0b8243e65bae93119ae7405cf26f5cbcc9e563c89b3961): failed to bind port 0.0.0.0:53/tcp: Error starting userland proxy: listen tcp4 0.0.0.0:53: bind: address already in use\n
I can see that some other service is using port 53.
How can I stop this or alter the config of Pihole??
Its propably incus using port 53 for internal dns resolution.
you can try with
sudo incus network set incusbr0 raw.dnsmasq="port=5354"
to rebind the incus port and free up port 53
Amazing!! Thanks for the rapid and very useful response!
That worked a treat!
this helped me reinstall pihole !! hey development team are you taking notes!?
Took me forever to get here but this solved my problem thank you.
This also resolved container creation erroring on 25.04
Thanks
If I may ask, how did you knew/guess it was incus?
and how would I go about stumbling my way into finding it was incus?
I appreciate the help immensely, my question is simply my drive to understand something I do not.
When incus was first announced i played around with it extensively to see if it can be a 1:1 replacement for my jailmaker nspawn-container which hosts my docker stack. One of the docker container i run in there is blocky, a dns-sinkhole like pi-hole which also needs port 53. I then googled around and found the command i posted in this tread above in a post on the incus forum.
So basically i’ve been in the same position 6 months ago :sweat_smile:
Does this raw.dnsmasq setting survive:
  • TrueNAS SCALE reboots?
  • TrueNAS SCALE upgrades?
It does for me. As already mentioned, changed it almost a year ago and did every update that truenas got during that time.
I just did the upgrade from 25.04 to 25.10, now that it is considered stable, and I had to run this command again to get Pihole working again. At least it was an easy fix.
Seeing as I had to redo this when I did the 25.10 upgrade, i’m presuming that this will revert with all upgrades (or at least significant ones), here’s a script to inject the incus networkcommand into the /etc/init.d/docker file so it will run on start of the docker service
#!/usr/bin/bash
set -e
PORT_TO_SET=5354
if [ "$(id -u)" != '0' ]; then
    echo "Must be run as root"
    exit 1
fi
function getThePort () {
  local portString
  portString=$(incus network get incusbr0 raw.dnsmasq || true | grep -oP 'port=\K\d+')
  echo "${portString#port=}"
thePort=$(getThePort)
initd=/etc/init.d/docker
if [[ ! -f "$initd" ]]; then
  echo "Docker init script not found at $initd. Exiting."
  exit 1
fi
if [[ -z "$thePort" ]]; then
    echo "No port found in incusbr0 configuration. Setting to default $PORT_TO_SET."
    thePort=$PORT_TO_SET
    doSet=true
elif [[ "$thePort" -ne "$PORT_TO_SET" ]]; then
    echo "Current DNS port is $thePort. Updating to $PORT_TO_SET."
    doSet=true
else
    echo "Port is already set to $PORT_TO_SET. No changes needed."
    doSet=false
fi
cmdOpen="incus network set incusbr0 raw.dnsmasq="
theCmd="${cmdOpen}\"port=$PORT_TO_SET\""
lineExists=$(grep -c "$cmdOpen" "$initd" || true)
if [[ "$doSet" == true || "$lineExists" -eq 0 ]]; then
    echo "Setting DNS port to $PORT_TO_SET."
    if [[ "$doSet" == true ]]; then
        # do it now
        eval "$theCmd"
        echo "DNS port updated to $PORT_TO_SET."
    fi
    # Inject the command into the init script before the start-stop-daemon line
    sed -i "/$cmdOpen/d" "$initd"
    sed -i "/start-stop-daemon --start/i\\        $theCmd" "$initd"
    echo "Injected command into $initd before start-stop-daemon line."
fi
also available as a github gist at https://gist.github.com/itsalljustdata/aff96c558b40f026fa5c572252e31ee9
