I’m considering using TrueNAS as part of a project to replace an ageing mini-ITX box. I’m not familiar with TrueNAS, although I worked as a sysadmin before retirement.
The question I have is regarding providing a spare drive for a vdev, and is probably best asked by way of an example. Suppose I have two NVMe slots available for a mirror, and a SATA slot which I’m intending to use for an emergency spare. I buy 2 identical 2TB NVMe drives, and a 2TB SATA drive from a different manufacturer.
When I come to commission the drives I find that the SATA drive is marginally smaller in terms of available blocks than the NVMe drives.
Is it possible with TrueNAS to create a mirror with the NVMe drives which is compatible with using the very slightly smaller drive as a spare? In my previous life I would have used partitions for this, by my understanding of TrueNAS is that this isn’t how things are done. Have I misunderstood something?
Thanks for any info, and apologies if this has a very obvious answer.
