Pool degraded for no obvious reason
Recently I got a critical alert in my TrueNAS dashboard about my Apps pool being degraded. When I go to storage, it shows as “Degraded, no errors.”
The pool consists of a single SSD as all important data is backed up to another drive. I cannot find any information on why the pool is actually degraded anywhere in the dashboard…. zpool status returns the following. It says “too many erorrs” and “No errors” at the same time…
pool: Apps
 state: DEGRADED
status: One or more devices has experienced an unrecoverable error.  An
        attempt was made to correct the error.  Applications are unaffected.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
  scan: scrub repaired 0B in 00:04:14 with 0 errors on Wed Jul 15 18:49:46 2026
        NAME                                    STATE     READ WRITE CKSUM
        Apps                                    DEGRADED     0     0     0
          9ef8a3ba-8af2-47ec-b84d-bfaf914018a1  DEGRADED     0     0     0  too many errors
errors: No known data errors
The SMART report also doesn’t seem to show anything problematic:
Model Family:     Crucial/Micron Client SSDs
Device Model:     CT250MX500SSD1
Serial Number:    1909E1EE85CF
LU WWN Device Id: 5 00a075 1e1ee85cf
Firmware Version: M3CR023
User Capacity:    250,059,350,016 bytes [250 GB]
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available
Device is:        In smartctl database 7.3/5528
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Wed Jul 15 18:33:36 2026 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (    0) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (  30) minutes.
Conveyance self-test routine
SCT capabilities:              (0x0031) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   100   100   000    Pre-fail  Always       -       0
  5 Reallocate_NAND_Blk_Cnt 0x0032   100   100   010    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       33374
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       660
171 Program_Fail_Count      0x0032   100   100   000    Old_age   Always       -       0
172 Erase_Fail_Count        0x0032   100   100   000    Old_age   Always       -       0
173 Ave_Block-Erase_Count   0x0032   141   141   000    Old_age   Always       -       3226
174 Unexpect_Power_Loss_Ct  0x0032   100   100   000    Old_age   Always       -       74
180 Unused_Reserve_NAND_Blk 0x0033   000   000   000    Pre-fail  Always       -       31
183 SATA_Interfac_Downshift 0x0032   100   100   000    Old_age   Always       -       2
184 Error_Correction_Count  0x0032   100   100   000    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   065   039   000    Old_age   Always       -       35 (Min/Max 0/61)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_ECC_Cnt 0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       36
202 Percent_Lifetime_Remain 0x0030   141   141   001    Old_age   Offline      -       215
206 Write_Error_Rate        0x000e   100   100   000    Old_age   Always       -       0
210 Success_RAIN_Recov_Cnt  0x0032   100   100   000    Old_age   Always       -       0
246 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       97108781451
247 Host_Program_Page_Count 0x0032   100   100   000    Old_age   Always       -       1925866677
248 FTL_Program_Page_Count  0x0032   100   100   000    Old_age   Always       -       27468873744
SMART Error Log Version: 1
Invalid Error Log index = 0x10 (valid range is from 1 to 5)
ATA Error Count: 0 (possibly also invalid)
# 1  Short offline       Completed without error       00%     33361         -
# 2  Short offline       Completed without error       00%     33341         -
# 3  Short offline       Completed without error       00%     33321         -
# 4  Extended offline    Completed without error       00%     33302         -
# 5  Short offline       Completed without error       00%     33302         -
# 6  Short offline       Completed without error       00%     23501         -
# 7  Extended offline    Completed without error       00%     25021         -
# 8  Short offline       Completed without error       00%     24957         -
# 9  Short offline       Completed without error       00%     24871         -
#10  Short offline       Completed without error       00%     24778         -
#11  Short offline       Completed without error       00%     24686         -
#12  Extended offline    Completed without error       00%     24634         -
#13  Short offline       Completed without error       00%     24594         -
#14  Short offline       Completed without error       00%     24502         -
#15  Short offline       Completed without error       00%     24411         -
#16  Short offline       Completed without error       00%     24318         -
#17  Extended offline    Completed without error       00%     24232         -
#18  Short offline       Completed without error       00%     24231         -
#19  Short offline       Completed without error       00%     24139         -
#20  Short offline       Completed without error       00%     24048         -
#21  Short offline       Completed without error       00%     23955         -
The above only provides legacy SMART information - try 'smartctl -x' for more
Is there anything else I can check to find out what the problem is? Is it safe to just clear the error of the zpool and see if it repeats?
No DATA errors, but too many DRIVE errors. It actually makes some sense, and you’re not the first to have issues with a Crucial MX500 SSD.
You may clear and wait… but prepare to replace (or mirror) the drive, just in case.
Now that I think about it, the alert may have popped up when I was replacing another failed disk. As I see SMART reports 2 SATA link downgrades and UDMA CRC errors I think they could be because I bumped the SATA cable of the disk when I was replacing the other one….
I’ll clear the zpool status as you recommended and see if the erorr repeats or not. Thanks!
