I’ve been running TrueNAS Scale (Cobia) on an old HP PC for a while, with 2x storage drives in RAID 1. Recently I started getting errors on one of the drives, and then the whole pool has gone offline. The disks are still visible, with SMART test failing on the bad drive, passing on the second one.
It is showing VDEVs not assigned, and when I try Import Pool there is nothing in the drop down. However when I try the Pool Creation Wizard it says: “The following disks have exported pools on them. Using those disks will make existing pools on them unable to be imported. You will lose any and all data in selected disks.” so I haven’t gone any further as I don’t want to lose all my data.
Before I go out and get a new disk to replace the failed one, is there anything I can do to get it working on the remaining drive so I can at least do a backup?
It says command not found if I don’t use sudo. If I do, this is what I get:
pool: storage
state: ONLINE
action: The pool can be imported using its name or numeric identifier.
storage ONLINE
mirror-0 ONLINE
72dda190-08f9-4174-b175-dd9dc9539c73 ONLINE
c2967e0b-caa9-44f7-a864-3106593c9ec4 ONLINE
So it looks like it can see the storage pool, what next?
A further choice might be to add -Fn to determine if the pool could be recovered. But would like to know if it’s an encrypted pool, wait on doing the -Fn
Pool feature upgrades are IMO best done only after your last TN upgrade is fully stable and you determine that you will never want to go back and before you attempt the next TN upgrade (so you don’t have too many pool features unavailable in the new release).
Yes - it certainly sounds like it is time to use the CLI to try to import the pool successfully. Once you have managed to import it successfully and made it work perfectly, then you can export it using the CLI and reimport it using the GUI.
I’ve made some progress, I have managed to import the storage pool using the CLI. I read somewhere I should then export and reimport using the GUI, is that correct? (I haven’t tried rebooting yet).
Anyway here is the output of sudo zpool status -xv
admin@truenas[~]$ sudo zpool status -xv
pool: storage
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
scan: scrub repaired 1M in 06:36:22 with 0 errors on Sat May 11 04:43:51 2024
NAME STATE READ WRITE CKSUM
storage ONLINE 0 0 0
mirror-0 ONLINE 5 0 0
72dda190-08f9-4174-b175-dd9dc9539c73 ONLINE 0 0 0
c2967e0b-caa9-44f7-a864-3106593c9ec4 ONLINE 5 0 0
There is also some weird behaviour, such as the Storage dashboard still showing 1 unassigned disk even though both disks are in the pool, and the main dashboard showing pool is offline even though it’s now showing up on the storage dashboard.
I also still can’t see the server folders on the network.
