Power Outage Causing Apps to fail
Good Morning, yesterday we suffered an extended power outage and this morning I can not get my apps service running. I get the below error when going to the apps page for the first time and then a second error message (further below). I’ve tried the unset/reset pool which throws this same error as the top code block. I’ve gone in and systemctl status docker shows docker is running but when I check docker ps -a there’s 0 containers.
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py”, line 323, in process_method_call
result = await method.call(app, params)
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py”, line 52, in call
result = await self.middleware.call_with_audit(self.name, self.serviceobj, methodobj, params, app)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 911, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 720, in _call
File “/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py”, line 93, in wrapped
result = await func(*args)
File “/usr/lib/python3/dist-packages/middlewared/plugins/catalog/apps.py”, line 21, in latest
await self.middleware.call(
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1005, in call
return await self._call(
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 731, in _call
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 624, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py”, line 101, in wrapped
result = func(*args)
File “/usr/lib/python3/dist-packages/middlewared/plugins/catalog/apps.py”, line 39, in available
for app in self.middleware.call_sync(‘app.query’)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1041, in call_sync
return methodobj(*prepared_call.args)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py”, line 72, in query
apps = list_apps(available_apps_mapping, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/query.py”, line 140, in list_apps
with os.scandir(get_app_parent_config_path()) as scan:
FileNotFoundError: [Errno 2] No such file or directory: ‘/mnt/.ix-apps/app_configs’
Error message beside the configuration drop down menu:
Application(s) have failed to start:
[EFAULT] Unable to determine default interface
I suspect it has something to do with the mapping/pairing of /mnt/.ix-apps/app-configs I can see that it is mounted? linked? to pool-storage/ix-apps/app_configs but not sure how to make the apps panel make those two friends.
Any assistance would be very much appreciated.
- JB
Your pool might be damaged from the power bump. You may want to scrub your pool. First, does /mnt/.ix-apps exist?
Stupid question - can you ping google.com and ping docker.com? I usually see that when ipv4 fails for whatever reason.
It seems that the ping is failing to both Google and Docker. This also happens from a desktop that can get to both. Maybe has something to do with my Pi-Hole? I do get the IP address back for each domain.
Sorry for the delayed reply. After Tuesday’s storm cutting power for 11 hours we lost power again yesterday for reasons unknown for another 11 hours. Guess it is a good thing I didn’t get started right away since power cut about an hour after I posted this question.
I’ve initiated the scrub. I’m guessing this is scrub of the storage pool that the apps are sitting on, not a data pool that may be reference by those apps, yes?
/mnt/.ix-apps does exist and contains:
@[~]$ ls /mnt/.ix-apps/
app_configs app_mounts docker metadata.yaml truenas_catalog user_config.yaml
Until TrueNAS can reach both it’ll keep failing to figure out the default interface. Once it can reach 'em refresh the catalogue, unset/reset the pool & you should be back in business.
