We run three Proxmox VE 9.2.4 nodes against a TrueNAS SCALE 25.10 array over NVMe/TCP in production, using the storage plugin from GitHub - truenas/truenas-proxmox-plugin: For providing seamless block storage to PVE · GitHub, with iSCSI on the side for testing. Three things came out of that. The first one is purely target-side and applies to any Linux initiator, not just Proxmox.
nvmet-tcp advertises no MDTS
The NVMe/TCP target in SCALE reports MDTS = 0, meaning “no limit”. A Linux initiator takes that literally and, on a namespace with a large NOWS, can build commands far beyond what the target will actually accept: nvmet_tcp_map_data() rejects anything above NVMET_TCP_MAXH2CDATA (4 MiB) with an SGL error, so the advertised limit and the enforced one are two different numbers. A patch to advertise a bounded MDTS is under review on linux-nvme; the discussion there also established that the target does not currently reject an over-MDTS command with Invalid Field as the spec requires, which needs a separate fix in the nvmet core. If you export NVMe/TCP namespaces from SCALE to Linux hosts this is worth knowing whatever hypervisor you run. On the Proxmox side we cap it meanwhile with the plugin option tn_nvme_max_io_kb 1024.
Snapshots taken on the TrueNAS side are invisible to Proxmox, and block rollback
If a periodic snapshot task (or a manual zfs snapshot) snapshots a zvol that backs a VM, Proxmox never learns about it. Two consequences: the snapshot does not appear in the Snapshots tab, and if it is newer than your last Proxmox snapshot, qm rollback refuses with “not most recent snapshot” and gives you no way to see or remove the one that is in the way. We wrote an importer that registers those snapshots in the guest configuration, for VMs and containers, using the ZFS creation time as the snapshot timestamp, so they show up in the GUI and can be rolled back to and deleted from Proxmox. It is PR #110 upstream.
The plugin: a fork with the fixes, and prebuilt packages
Upstream is moving fast in beta and several things bit us, so we keep a fork with the fixes applied and packaged builds, and send everything back as pull requests. Open upstream right now besides the importer: a portal that was down at connect time is never retried (#94), iSCSI CHAP against 25.10 (#95), and unbounded API retries that stall pvestatd while the array is unreachable (#97). We also reported that the install.sh linked from the README is from an older lineage and fails with “broker: scfg missing api_host/api_key” (#107).
Packages, sha256 and per-release notes: Releases · alfonsokuen/truenas-proxmox-plugin · GitHub
Happy to answer questions here, and to hear from anyone running the same combination.
