i was also double checking with stux video on the networking portion.
mine doesnāt look right
root@docker:~# nano /etc/systemd/network/80-container-host0.network
root@docker:~# reboot
root@docker:~#
Connection to machine docker terminated.
root@xxxxx[~]# jlmkr shell docker
Connected to machine docker. Press ^] three times within 1s to exit session.
root@docker:~# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: host0@if15: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether xxxxx link-netnsid 0
inet 192.168.0.24/24 brd 192.168.0.255 scope global host0
3: br-4fxxxxxb8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
link/ether 0xxxxx
inet 172.18.0.1/16 brd 172.18.255.255 scope global br-4fxxxxxb8
inet6 fe80::xxxxx/64 scope link
4: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether xxxxx
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
6: vethf2c204a@if5: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-xxxxxb8 state UP group default
link/ether xxxxx link-netnsid 1
inet6 xxxxx/64 scope link
root@docker:~#
the 192.168.0.24 is there, but when i docker ps -a the dockge container is only showing 0.0.0.0
last time in a working setup it showed 192.168.0.24
not sure what happened there
root@xxxx[~]# ifconfig
br1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.210 netmask 255.255.255.0 broadcast 192.168.0.255
ether xxxx xxxx 1000 (Ethernet)
RX packets 4641 bytes 467638 (456.6 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 1643 bytes 48530899 (46.2 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp19s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 xxxx prefixlen 64 scopeid 0x20<link>
ether xxxx txqueuelen 1000 (Ethernet)
RX packets 4841 bytes 624438 (609.8 KiB)
RX errors 0 dropped 5 overruns 0 frame 0
TX packets 33866 bytes 50271212 (47.9 MiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 1381 bytes 344653 (336.5 KiB)
TX packets 1381 bytes 344653 (336.5 KiB)
vb-docker: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
RX packets 39 bytes 2103 (2.0 KiB)
RX errors 0 dropped 6 overruns 0 frame 0
TX packets 267 bytes 94226 (92.0 KiB)
root@xxxx[~]#
isnāt vb docker suppose to be 192.168.0.24 ?
*update
root@xxxxx[~]# jlmkr list
NAME RUNNING STARTUP GPU_INTEL GPU_NVIDIA OS VERSION ADDRESSES
docker True True False True debian 12 192.168.0.24ā¦
root@xxxxx[~]#
ok i see the ip for docker when checking.
but the docker compose isnāt using the ip for some reason?
