ty u i appreciate and definitely will check it out. i just finish up immich then call it a day first xd ![]()
i will schedule that for tomorrow, thx again
so after deploying immich, opened the app, browse around, toggle on transcoding (later switch it off cauz i don’t need that), then tested task for scan new faces etc, then ran a search seemed fast.
checked dozzle did not see any errors mentioned. i can only conclude it works.
if there is a better way to test it conclusively, plz let me know.
afaik i ran a search for moogles and the return result was pretty fast ![]()
well spotted 2 mistakes. in 2 of them were both girls. unless the machine learning discovered Tanya was a dude but was reborn as a girl, then that would be pretty impressive. But i’m sure it was a mistake ![]()
one thing that impressed me about Immich was how they lock down face boxes almost perfectly
Hardware-Accelerated Machine Learning [Experimental]
This feature allows you to use a GPU to accelerate machine learning tasks, such as Smart Search and Facial Recognition, while reducing CPU load. As this is a new feature, it is still experimental and may not work on all systems.
as i thought, the reason why smart search was fast was because it’s accelerated. so yes for me there is a benefit.
I guess that also applies for facial recognition. while indexing and perhaps looking for a similar face.
But yes it’s very responsive when running the smart search. Is it worth buying graphic card just for that? don’t know but i liked the performance.
Immich is great but what is fares poorly is in importing existing folders to create virtual albums. There are third party work arounds using unofficial scripts. But most know not to run scripts over the internet from unknown origins, it’s rarely ever safe doing. That said i tried one of them and it worked. But when will they officially add that feature to Immich? no idea, but it’s what’s holding it back from being the best solution imho.
did i speak too soon? not sure what this is, but it’s under machine learning
8/04/2024
[04/28/24 ] INFO Initialized request thread pool with 8 threads.
28/04/2024
[04/28/24 ] INFO Application startup complete.
28/04/2024
22:37:54
[04/28/24 ] INFO Setting 'ViT-B-32__openai' execution providers to
28/04/2024
['CUDAExecutionProvider', 'CPUExecutionProvider'],
28/04/2024
in descending order of preference
28/04/2024
[04/28/24 ] INFO Loading clip model 'ViT-B-32__openai' to memory
28/04/2024
2024-04-28 xxxxxxxxxxxx [W:onnxruntime:, transformer_memcpy.cc:74 ApplyImpl] 15 Memcpy nodes are added to the graph main_graph for CUDAExecutionProvider. It might have negative impact on performance (including unable to run CUDA graph). Set session_options.log_severity_level=1 to see the detail logs before this message.
28/04/2024
[04/28/24 ] INFO Shutting down due to inactivity.
28/04/2024
[04/28/24 14:47:08] INFO Shutting down
28/04/2024
[04/28/24 ] INFO Waiting for application shutdown.
28/04/2024
[04/28/24 14:47:08] INFO Application shutdown complete.
28/04/2024
[04/28/24 14:47:08] INFO Finished server process [48]
28/04/2024
[04/28/24 14:47:08] ERROR Worker (pid:48) was sent SIGINT!
28/04/2024
[04/28/24 14:47:08] INFO Booting worker with pid: 77
28/04/2024
[04/28/24 14:47:13] INFO Started server process [77]
28/04/2024
[04/28/24 14:47:13] INFO Waiting for application startup.
28/04/2024
[04/28/24 14:47:13] INFO Created in-memory cache with unloading after 300s
28/04/2024
of inactivity.
28/04/2024
[04/28/24 14:47:13] INFO Initialized request thread pool with 8 threads.
28/04/2024
[04/28/24 14:47:13] INFO Application startup complete.
this got flagged as an error twice
**ERROR** Worker **(** pi**d:48** **)** was sent SIGINT!
so i ran another smart search and noted down the exact activity in the logs
28/04/2024
28/04/2024
28/04/2024
28/04/2024
28/04/2024
2024-04-28 xxxxxxxxxx [W:onnxruntime:, transformer_memcpy.cc:74 ApplyImpl] 15 Memcpy nodes are added to the graph main_graph for CUDAExecutionProvider. It might have negative impact on performance (including unable to run CUDA graph). Set session_options.log_severity_level=1 to see the detail logs before this message.
so all it output was this. no error i assume
well i did this
checks for updates but doesn’t update
sudo apt-get update
root@docker:~# apt list --upgradable
this updates anything it finds outdated
sudo apt-get update -y && sudo apt-get upgrade -y
hm
The following packages will be upgraded:
docker-ce docker-ce-cli
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
then i exit restart jlmkr restart docker
jlmkr shell docker
root@docker:~# docker version
Client: Docker Engine - Community
Version: 26.1.0
API version: 1.45
Go version: go1.21.9
Git commit: 9714adc
Built: Mon Apr 22 xxxxxxx 2024
OS/Arch: linux/amd64
Context: default
Server: Docker Engine - Community
Engine:
Version: 26.1.0
API version: 1.45 (minimum version 1.24)
Git commit: c8af8eb
Built: Mon Apr 22 xxxxx 2024
Experimental: false
containerd:
Version: 1.6.31
GitCommit: e377cdxxxxxxxxxxx94a521
runc:
Version: 1.1.12
GitCommit: v1.1.12-0-g51d5e94
docker-init:
Version: 0.19.0
GitCommit: de40ad0
root@docker:~#
seems to be latest
do my docker containers work? ya tested all fine ![]()
*update
some good ideas for how to go about updating in jailmaker
and if you are wondering
https://www.reddit.com/r/termux/comments/nxhpvj/pkg_vs_apt/
We strongly recommend to use a pkg utility instead of apt directly. It is a wrapper that performs a number of tasks:
- Provides command shortcuts. Use “pkg in” instead of “pkg install” or “apt install”.
- Automatically runs “apt update” before installing a package if necessary.
- Performs some client side repository load-balancing by automatically switching mirrors on a regular basis. That is important to prevent us hitting quota limit on hosting.
is it alright to use apt?
As long as you manually run apt update before you try to install something you will be alright
studying up cron jobs. so can schedule updates for docker and stuff ![]()
https://www.truenas.com/docs/scale/scaletutorials/systemsetting
credits to dan for the idea also to winnie
hm, truenas > system settings > advanced
but how do u run a cron job within jailmaker shell docker to perform the pkg update -f && pkg upgrade
Execute Command in Jail
You may want to execute a command inside a jail, for example from a shell script or a CRON job. The example below executes the
envcommand inside the jail.
jlmkr exec myjail envThis example executes bash inside the jail with a command as additional argument.
jlmkr exec myjail bash -c 'echo test; echo $RANDOM;'
so i assume
jlmkr exec myjail shell -c 'pkg update -f && pkg upgrade;'
is that correct? but it’s missing cron hm x-x;
according to this, you specify a file type to run
https://www.ibm.com/docs/kk/aix/7.1?topic=c-crontab-command
To run a script called maintenance every day at midnight in August, enter the following:
0 0 * 8 * /u/harry/bin/maintenance
to translate the numbers for cron and the formating used
Found a solution for immich to copy pics from existing folders.
but does that create albums in immich based on those folders (which is what i want) ? also when he said copy files, is that a symlink? or an actual full sized file meaning you are now storing double the file size because you are storing 2 exact copies on the same machine? hopefully that is not the case.
detailed explanation how immich handles the image imports/external libraries
If you are new to immich, think about this. Your only option for importing pics is either the upload, or the import external libraries.
Imagine you already have folders setup and you labeled them nicely e.g. cats, dogs… etc. So you want to add them to Immich to keep them separated by their folder structure you painstakingly did beforehand.
Immich by default can’t do that… instead, it all goes into one location. once done, then you can create albums, For which they then expect you to select the picks you want to put in that album.
So more work for you to do.
Question then, why can’t they simply create albums based on folders already setup?
Photoprism can do this already. But immich can’t
That is Immich’s only sore point imho. But there are hacks around that but it ain’t pretty and potentially risk hazard if you accidentally run a malicious script some rando posted over the internet.
credits to Davvo ![]()
root@xxxx[~]# jlmkr exec docker bash crontab -e
bash: crontab: No such file or directory
root@xxxx[~]#
root@xxxx[~]# jlmkr shell docker
Connected to machine docker. Press ^] three times within 1s to exit session.
root@docker:~# crontab -e
bash: crontab: command not found
root@docker:~# bash crontab -e
root@docker:~#
figured it out /cd derp
im tired and been using shell too much lately.
root@xxx[~]# cd /mnt/xxxxxxxx/jailmaker/jails/docker
root@xxx[/mnt/xxxxxxxx/jailmaker/jails/docker]# select-editorSelect an editor. To change later, run ‘select-editor’.
- /bin/nano <---- easiest
- /usr/bin/mcedit
- /usr/bin/vim.tiny
Choose 1-3 [1]: 3
root@xxxxx[/mnt/xxxxx/jailmaker/jails/docker]# crontab -e
no crontab for root - using an empty one
crontab: installing new crontab
“/tmp/crontab.0ZSNCD/crontab”:23: bad minute
errors in crontab file, can’t install.
Do you want to retry the same edit? (y/n)
i used nano but that didn’t work so i did this to switch to vim
select-editor
now i can follow instructions. but when i tried to save, it couldn’t. bit confused ![]()
Mine and @winnielinnie’s instructions were for FreeBSD jails. For Linux, refer to How to Edit Crontab in Linux? - Scaler Topics. Main difference is just vi commands.
