I have a Truenas Scale (25.10.1 community) system set up with five 3TB drives in one pool. Recently, I purchased two 4TB drives to add to the pool. My question is, will this be a straightforward process (install the drives, expand the pool, on we go) or do I have to do something special to make it happen? As far as I know, the pool is the basic general ZFS pool without anything special done to it.
The data vdev has this for the stats: 1 x RAIDZ2 | 5 wide | 2.73 TiB for a total of 8.01TB currently. And it’s currently at 100% used space (I have backups that I can remove to free up space and possibly log files that can be removed as well).
And keep in mind, you’ll have to extend the vdev one disk at a time, and it will take a while. The progress will only be visible via cli.
After expansion, you could use zfs rewrite -rvx /path/to/dataset/folder to recoup some space lost due to the expansion, but that also will take a while, and can’t be paused.
So another question. I have the “Add to Pool” button and it shows 4 unassigned disks (two are 119GB SSD’s or NvME drives that were in the Freenas when I bought it and the others are my 4TB drives. They show as 3.64 TiB drives). Would I be able to use that to get the drives into my pool? After I free up some space, I mean.
