RAIDZ Expansion incredible slow
Hi everybody,
A week ago I started the expansion of my RAID-Z2 pool.
The expansion is extremely slow and I would love to figure out why.
Things I’ve tried:
I don’t think that my drive speed is the limit:
CPU Graph
zpool iostat -v
                                            capacity     operations     bandwidth
pool                                      alloc   free   read  write   read  write
HDDs                                      12.2T  9.68T    267    554  3.20M  3.34M
  raidz2-0                                12.2T  9.68T    267    554  3.20M  3.34M
    7ac7e694-c157-4820-aa65-1e56eca33e81      -      -      1     49   819K   685K
    11d74cd6-9481-4f2b-b05b-bd0e7f7a0428      -      -      1     51   819K   685K
    f6f2eefe-0b8b-4401-b238-adce4ddbcded      -      -    131    157   818K   685K
    9fa1a40c-74a5-4f01-b1fb-de3cbbf99d51      -      -    133    159   818K   685K
    07dd1749-3341-4cfb-8cd0-cdb70a5ce014      -      -      0    137    372   678K
boot-pool                                 7.82G   224G      0     10  3.23K   114K
  nvme0n1p3                               7.82G   224G      0     10  3.23K   114K
iostat -x
Linux 6.6.44-production+truenas (Nexus)         01/28/25        _x86_64_        (4 CPU)
avg-cpu:  %user   %nice %system %iowait  %steal   %idle
           3.61    0.17    3.02   25.20    0.00   68.00
Device            r/s     rkB/s   rrqm/s  %rrqm r_await rareq-sz     w/s     wkB/s   wrqm/s  %wrqm w_await wareq-sz     d/s     dkB/s   drqm/s  %drqm d_await dareq-sz     f/s f_await  aqu-sz  %util
loop1            0.01      0.28     0.00   0.00    0.06    55.27    0.00      0.00     0.00   0.00    0.00     0.00    0.00      0.00     0.00   0.00    0.00     0.00    0.00    0.00    0.00   0.00
loop2            0.00      0.01     0.00   0.00    0.16    18.88    0.00      0.00     0.00   0.00    0.00     0.00    0.00      0.00     0.00   0.00    0.00     0.00    0.00    0.00    0.00   0.00
nvme0n1          0.11      3.41     0.00   0.02    0.15    32.29   11.27    113.51     0.00   0.00    0.05    10.07    0.00      0.00     0.00   0.00    0.00     0.00    0.29    0.34    0.00   0.03
sda            133.69    817.65     0.09   0.07    0.14     6.12  159.32    684.90     0.03   0.02    0.12     4.30    0.00      0.00     0.00   0.00    0.00     0.00    0.11    7.51    0.04   2.39
sdb              1.84    819.07     0.00   0.08  132.00   445.91   51.24    684.72     0.03   0.05   39.73    13.36    0.00      0.00     0.00   0.00    0.00     0.00    0.11  156.90    2.30  97.77
sdc              1.84    819.11     0.00   0.07  129.35   446.21   50.15    684.75     0.03   0.05   40.86    13.65    0.00      0.00     0.00   0.00    0.00     0.00    0.11  157.77    2.30  97.82
sdd            131.09    817.68     0.10   0.08    0.18     6.24  157.50    684.89     0.02   0.01    0.14     4.35    0.00      0.00     0.00   0.00    0.00     0.00    0.11    8.67    0.05   2.73
sde              0.02      0.42     0.00   0.20   53.13    21.69  137.16    677.51     0.03   0.03    3.74     4.94    0.00      0.00     0.00   0.00    0.00     0.00    0.11   68.98    0.52  24.67
I’ve noticed in iostat -x that sdb and sdc are at full utillization:
  • sdb, sdc, sde are WD60EFAX
  • sda, sdd are WD60EFZX
which is weird, because the FAX should be better than the FZX…
Is this ZFS PR related?
System Specs
  • ElectricEel-24.10.1
  • CPU: Intel N100
  • HDD: 5x WD Red Pro
    • Connected via SATA
    • Split over 4 PCIe Lanes
  • RAM: 16GB
Is there anything I can do to speed up the expansion?
Or do I just have to wait until it finishes in a few months?
Also, why does the expansion need to go through the whole 12TB of my pool, while only ~7TB are used?
SMR drives. Look no further and seek to replace these drives as soon as possible: They are not suitable for raidz#, as your are painfully finding out.
@etorix thank you for your answer!
During day-to-day use I’ve experienced little to no performance degradation, only running the ZFS expand (and based on online research probably also a resilver) significantly harms the performance.
Do you guys think that I could wait for the expand to finish, and after that replace each drive one by one?
Would SMR drives also tank the performance when replacing a drive?
In that case I think it would be better to restore from a backup…
If it is the SMR drive that is written to - yes. If you replace SMR with CMR and the SMR drives are only read, you should be fine.
I don’t know if one can cancel an expand operation once started, sorry.
@pmh Thanks! no its unfortunately not possible to cancel the expansion.
If you have a backup and you are already pondering to start from scratch, you might just give it a try to yank the two new disks and replace them with two CMR ones. After all you do have two disks of redundancy, currently.
Anyone else with actual experience on how exactly to go about this? Add the new drives (assuming there is space and SATA ports) and start a replace operation while the expansion is running? Or literally yank them?
I believe the expansion is supposed to pause while the pool is degraded/resilvering.
I would expect you can replace the disks as per usual and when the replacement finishes, then the expansion will resume.
SMR drives are only slow to be written too, so replacing them should be relatively fast.
/me shakes fist at WD again…
Yes. I understand that, contrary to a mirror resilver, ZFS writes to all disks during a raidz resilver.
If you do have a backup, and all drives for the new pool, just fall back on “backup-destroy-restore” and skip replacing, expanding, rebalancing, and still living with botched space reporting everafter.
This is not my understanding, but it is true for RaidZ Expansions.
I think what he meant is that for each block read, a block must also be read from each of the surviving drive in the vdev. That makes it x-times way more IO-heavy than a simple mirror resilvering and also one of the primary reasons why resilvers times are orders of magnitudes slower in RAIDZ.
Don’t forget that reading from SMR disks can be slower too, compared to CMR disks. This is because the data can be in essence fragmented. ZFS has no knowledge of where the data is, just makes read block requests.
If the SMR drive has re-shingled the data, potentially over and over again, it can end up so fragmented over the disk that it could potentially take several times longer than a simple CMR disk read.
Only thing I can comment is that when I did an expansion of a (I can’t remember exactly either 12-18tb pool) it took about 3 or four full days for it to complete…that’s just how it is especially when you don’t have the proper drives apparently
I just noticed that the OP is very misleading.
You claimed that they’re WD Red Pro’s (which are indeed CMR’s), but it’s nothing of the sort:
  • WD60EFAX are just vanilla WD Red (which are SMR’s).
  • WD60EFZX are WD Red Plus (Still NOT Pro’s, but at least are CMR’s).
I blame WD for all the confusion in that lineup. I can understand how the OP would have made that mistake.
I’m in the process of expanding from 6 - 7 Seagate Ironwolfs12tb. Pool 47% full. Going to take 22 hours to do…
