Raidz1 with 3 disks does not have expected capacity
I am creating a new pool (for offsite backup) with 3 - 2TB drives. They are mixed brands and rpms so I expect performance to be poor. The problem I am running into is: The pool’s capacity is on only 50% of what I am expecting. Can someone help me understand/troubleshoot this?
Welcome to the TrueNAS forums!
It almost seems like you have a smaller disk in the RAID-Z1 set. Except one of your screen shots shows 3 x 2TB disks…
Please supply the output of the following commands in CODE tags;
zpool list -v
zpool status
lsblk
This should help determine the problem.
Further, did you setup any ZFS quota, reservations?
Thanks for the response!
I have been trying various things since the original setup.
I tried creating 3 separate pools, one for each drive, to see which drives are causing trouble.
sda: looks fine,
sdk: 50% capacity,
sdl: 50% capacity
So I tried to “Expand Pool”:
sda: sucess, no change,
sdk: immediately faulted,
sdl: didn’t work, I think it was because of the running task on sdk and I didn’t want to wait.
So I deleted the pool with sdl and started a full disk wipe with random zero. I was not able to export sdk since it still had an “expand” job running.
Here are the relevant sections of the commands you asked for:
root@truenas[/home/admin]# zpool list -v
NAME                                       SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP    HEALTH  ALTROOT
ait2408                                   14.5T  4.08T  10.5T        -         -     0%    28%  1.00x    ONLINE  /mnt
  raidz1-0                                14.5T  4.08T  10.5T        -         -     0%  28.0%      -    ONLINE
    c62ab49a-dd76-4905-ba8b-f761866178ec  3.64T      -      -        -         -      -      -      -    ONLINE
    7cfb5e69-dfa2-4172-97de-e70f3fa6ca84  3.64T      -      -        -         -      -      -      -    ONLINE
    3172644c-64b5-4de2-9e37-8dbc73e5f30a  3.64T      -      -        -         -      -      -      -    ONLINE
    d76a47bb-b2fa-439c-a2c3-5d47447a4bc1  3.64T      -      -        -         -      -      -      -    ONLINE
boot-pool                                   95G  10.2G  84.8G        -         -     3%    10%  1.00x    ONLINE  -
  mirror-0                                  95G  10.2G  84.8G        -         -     3%  10.7%      -    ONLINE
    sdg3                                  95.3G      -      -        -         -      -      -      -    ONLINE
    sdi3                                  95.3G      -      -        -         -      -      -      -    ONLINE
pcs_backup                                3.62T  2.30T  1.32T        -         -    12%    63%  1.00x    ONLINE  /mnt
  745aed7c-ca22-41d0-9bac-5d4182bec4ee    3.64T  2.30T  1.32T        -         -    12%  63.5%      -    ONLINE
pny-ssd-pool                              1.81T   684G  1.14T        -         -    30%    36%  1.00x    ONLINE  /mnt
  03cbf51d-fc09-469f-8c88-d142507634cb     930G   339G   589G        -         -    31%  36.5%      -    ONLINE
  563dd475-6100-4e05-9e8a-c86e737e9c6c     930G   346G   582G        -         -    29%  37.2%      -    ONLINE
test1                                     1.81T   540K  1.81T        -         -     0%     0%  1.00x    ONLINE  /mnt
  1e0e1882-800c-4fc4-a5d6-0c04b18cd077    1.82T   540K  1.81T        -         -     0%  0.00%      -    ONLINE
test2                                      928G   456K   928G        -         -     0%     0%  1.00x  SUSPENDED  /mnt
  22c2b5dd-54d2-4489-a14c-17857767cf9f     932G   456K   928G        -         -     0%  0.00%      -   FAULTED
### trimmed
pool: test1
 state: ONLINE
        NAME                                    STATE     READ WRITE CKSUM
        test1                                   ONLINE       0     0     0
          1e0e1882-800c-4fc4-a5d6-0c04b18cd077  ONLINE       0     0     0
errors: No known data errors
  pool: test2
 state: SUSPENDED
status: One or more devices are faulted in response to IO failures.
action: Make sure the affected devices are connected, then run 'zpool clear'.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-JQ
        test2                                   FAULTED      0     0     0  corrupted data
          22c2b5dd-54d2-4489-a14c-17857767cf9f  FAULTED      0     0     0  corrupted data
errors: 4 data errors, use '-v' for a list
root@truenas[/home/admin]# lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINTS
sda           8:0    0   1.8T  0 disk
└─sda1        8:1    0   1.8T  0 part
sdb           8:16   0   3.6T  0 disk
├─sdb1        8:17   0     2G  0 part
└─sdb2        8:18   0   3.6T  0 part
sdc           8:32   0   3.6T  0 disk
└─sdc1        8:33   0   3.6T  0 part
sdd           8:48   0   3.6T  0 disk
└─sdd1        8:49   0   3.6T  0 part
sde           8:64   0 931.5G  0 disk
├─sde1        8:65   0     2G  0 part
└─sde2        8:66   0 929.5G  0 part
sdf           8:80   0   3.6T  0 disk
└─sdf1        8:81   0   3.6T  0 part
sdg           8:96   0 111.8G  0 disk
├─sdg1        8:97   0     1M  0 part
├─sdg2        8:98   0   512M  0 part
├─sdg3        8:99   0  95.3G  0 part
└─sdg4        8:100  0    16G  0 part
  └─md127     9:127  0    16G  0 raid1
    └─md127 253:0    0    16G  0 crypt
sdh           8:112  0   3.6T  0 disk
└─sdh1        8:113  0   3.6T  0 part
sdi           8:128  0 111.8G  0 disk
├─sdi1        8:129  0     1M  0 part
├─sdi2        8:130  0   512M  0 part
├─sdi3        8:131  0  95.3G  0 part
└─sdi4        8:132  0    16G  0 part
sdj           8:144  0 931.5G  0 disk
├─sdj1        8:145  0     2G  0 part
└─sdj2        8:146  0 929.5G  0 part
sdk           8:160  0   1.8T  0 disk
└─sdk1        8:161  0 931.5G  0 part
sdl           8:176  0   1.8T  0 disk
I now have some more questions.
  1. How can I cancel jobs? That pool expand job is still running at 0%
  2. Just yesterday I did a long SMART test on all 3 of these drives and they all came back with “success”. How can I access the results of the smart tests and does success mean “no errors”?
  3. If the drive has errors like this, does it always mean the drive needs to be replaced or can I assume this error has to do with how it it formatted?
smartctl -a /dev/sda
smartctl -a /dev/sdk
smartctl -a /dev/sdl
Not necessarily.
Start from providing the required outputs, we have to evaluate the situation.
Also, do note that 1.8 TiB ≈ 2 TB.
There is nothing wrong with experimenting with an empty NAS server, but boy what a mess you currently have.
A few things you need to do:
  1. Get the exact models of your hard drives and check that that specific model is NOT a SMR technology disk. SMR disks are not useable for redundant vDevs with TrueNAS/ZFS.
  2. Your pny-ssd-pool is striped without any redundancy - this is NOT a good idea as if one drive dies you will lose the data on the other drive as well.
  3. When you are ready to create your production pools, ask for advice about the best setup for the hardware you have. In general terms, vDevs have to use disks of similar sizes (otherwise the space on bigger drives will be wasted), but you can have multiplke vDevs in a pool. For VMs and Apps you do not want to use RAIDZ, and SSDs are best if your data sizes are not too big. For HDDs, generally it is better to have a single pool, but there are circumstances where you may want to split pools.
type or root@truenas[/home/admin]# smartctl -a /dev/sda
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.32-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Hitachi Ultrastar A7K2000
Device Model:     Hitachi HUA722020ALA331
Serial Number:    BFHG150F
LU WWN Device Id: 5 000cca 229d4790f
Firmware Version: JKAOA3NH
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5528
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Tue Aug 20 16:37:42 2024 CDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (22036) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 367) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   133   133   054    Pre-fail  Offline      -       102
  3 Spin_Up_Time            0x0007   111   111   024    Pre-fail  Always       -       647 (Average 650)
  4 Start_Stop_Count        0x0012   099   099   000    Old_age   Always       -       5622
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   121   121   020    Pre-fail  Offline      -       35
  9 Power_On_Hours          0x0012   091   091   000    Old_age   Always       -       68103
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       94
192 Power-Off_Retract_Count 0x0032   096   096   000    Old_age   Always       -       5872
193 Load_Cycle_Count        0x0012   096   096   000    Old_age   Always       -       5872
194 Temperature_Celsius     0x0002   240   240   000    Old_age   Always       -       25 (Min/Max 19/56)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
ATA Error Count: 3736 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 3736 occurred at disk power-on lifetime: 34730 hours (1447 days + 2 hours)
  ER ST SC SN CL CH DH
  40 51 05 4b 18 f7 02  Error: UNC at LBA = 0x02f7184b = 49748043
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 08 08 48 18 f7 40 00  33d+19:28:09.469  READ FPDMA QUEUED
  ef 02 00 00 00 00 00 00  33d+19:28:09.467  SET FEATURES [Enable write cache]
  60 08 08 48 18 f7 a0 ff  33d+19:28:09.249  READ FPDMA QUEUED
  60 08 08 48 18 f7 a0 ff  33d+19:28:09.243  READ FPDMA QUEUED
  60 08 08 48 18 f7 40 00  33d+19:27:52.616  READ FPDMA QUEUED
Error 3735 occurred at disk power-on lifetime: 34730 hours (1447 days + 2 hours)
  ef 02 00 00 00 00 00 00  33d+19:27:52.614  SET FEATURES [Enable write cache]
  60 08 08 48 18 f7 a0 ff  33d+19:27:52.414  READ FPDMA QUEUED
  60 08 08 48 18 f7 a0 ff  33d+19:27:52.408  READ FPDMA QUEUED
  60 08 08 48 18 f7 40 00  33d+19:27:35.762  READ FPDMA QUEUED
Error 3734 occurred at disk power-on lifetime: 34730 hours (1447 days + 2 hours)
  ef 02 00 00 00 00 00 00  33d+19:27:35.760  SET FEATURES [Enable write cache]
  60 08 08 48 18 f7 a0 ff  33d+19:27:35.680  READ FPDMA QUEUED
  60 08 08 48 18 f7 a0 ff  33d+19:27:35.675  READ FPDMA QUEUED
  60 08 08 48 18 f7 40 00  33d+19:27:19.003  READ FPDMA QUEUED
Error 3733 occurred at disk power-on lifetime: 34730 hours (1447 days + 2 hours)
  ef 02 00 00 00 00 00 00  33d+19:27:19.002  SET FEATURES [Enable write cache]
  60 08 08 48 18 f7 a0 ff  33d+19:27:18.795  READ FPDMA QUEUED
  60 08 08 48 18 f7 a0 ff  33d+19:27:18.789  READ FPDMA QUEUED
  60 08 08 48 18 f7 40 00  33d+19:27:02.150  READ FPDMA QUEUED
Error 3732 occurred at disk power-on lifetime: 34730 hours (1447 days + 2 hours)
  ef 02 00 00 00 00 00 00  33d+19:27:02.148  SET FEATURES [Enable write cache]
  60 08 08 48 18 f7 a0 ff  33d+19:27:02.061  READ FPDMA QUEUED
  60 08 08 48 18 f7 a0 ff  33d+19:27:02.056  READ FPDMA QUEUED
  60 08 08 48 18 f7 40 00  33d+19:26:45.391  READ FPDMA QUEUED
# 1  Extended offline    Completed without error       00%      2552         -
# 2  Short captive       Completed without error       00%     20918         -
# 3  Short offline       Completed without error       00%     20004         -
The above only provides legacy SMART information - try 'smartctl -x' for more
root@truenas[/home/admin]# smartctl -a /dev/sdk
Model Family:     Seagate Barracuda LP
Device Model:     ST32000542AS
Serial Number:    5XW1VLEV
LU WWN Device Id: 5 000c50 02e93115b
Firmware Version: CC34
Rotation Rate:    5900 rpm
Local Time is:    Tue Aug 20 16:38:07 2024 CDT
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/213915en
                                        been run.
data collection:                (  633) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 453) minutes.
Conveyance self-test routine
SCT capabilities:              (0x103f) SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   120   099   006    Pre-fail  Always       -       235700753
  3 Spin_Up_Time            0x0003   100   100   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   096   096   020    Old_age   Always       -       4358
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   041   041   030    Pre-fail  Always       -       5647897819954
  9 Power_On_Hours          0x0032   068   068   000    Old_age   Always       -       28196
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       132
183 Runtime_Bad_Block       0x0032   001   001   000    Old_age   Always       -       17520
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       27
189 High_Fly_Writes         0x003a   099   099   000    Old_age   Always       -       1
190 Airflow_Temperature_Cel 0x0022   076   058   045    Old_age   Always       -       24 (Min/Max 19/27)
194 Temperature_Celsius     0x0022   024   042   000    Old_age   Always       -       24 (0 16 0 0 0)
195 Hardware_ECC_Recovered  0x001a   030   030   000    Old_age   Always       -       235700753
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   163   000    Old_age   Always       -       17490
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       6805 (74 0 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       554583647
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       2466595393
No Errors Logged
# 1  Extended offline    Completed without error       00%     28180         -
# 2  Short offline       Completed without error       00%     27884         -
# 3  Short offline       Completed without error       00%     27883         -
root@truenas[/home/admin]# smartctl -a /dev/sdl
Device Model:     HITACHI HUS724020ALA640
Serial Number:    P6HADWHP
LU WWN Device Id: 5 000cca 22dd2d397
Firmware Version: MF6ONS00
Device is:        Not in smartctl database 7.3/5528
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Aug 20 16:38:12 2024 CDT
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (18963) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 316) minutes.
  2 Throughput_Performance  0x0005   100   100   054    Pre-fail  Offline      -       0
  3 Spin_Up_Time            0x0007   186   186   024    Pre-fail  Always       -       322 (Average 350)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       29
  8 Seek_Time_Performance   0x0005   100   100   020    Pre-fail  Offline      -       0
  9 Power_On_Hours          0x0012   095   095   000    Old_age   Always       -       37392
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       29
192 Power-Off_Retract_Count 0x0032   099   099   000    Old_age   Always       -       1584
193 Load_Cycle_Count        0x0012   099   099   000    Old_age   Always       -       1584
194 Temperature_Celsius     0x0002   214   214   000    Old_age   Always       -       28 (Min/Max 20/60)
No Errors Logged
# 1  Extended offline    Completed without error       00%     37374         -
# 2  Short offline       Completed without error       00%     26980         -
root@truenas[/home/admin]# paste code here
Thanks!
  1. The exact models seem to be included with smart reporting. I will try to find whether they are SMR shortly.
  2. I understand the risk. Most of the data on the pny-ssd-pool is static and I replicate that pool to the ait2408 pool every night. There is a chance I would lose data but unless I also loose the other backup pool it will at most be a day.
  3. Yes, I am interested in some input on a good setup. I was not aware that RAIDZ is not good for apps and VMs but it makes sense.
Some explanation of the rest of the mess. I have 3 pools in here.
  1. ssd storage
  2. HDD backup
  3. pcs_backup single drive. This is an offsite backup for someone else who has various other backups. If this fails no data is lost unless other terrible things happen at the same.
The rest of the pools are simply to test the drives in question.
Update:
I have not been able to find whether the Hitachi Ultrastar A7K2000 is SMR or not.
The Seagate Barracuda LP seems to be according to this, if Barracuda is same as Barracuda LP
I have not been able find information on the HITACHI HUS724020ALA640 either
These are drives I had laying around and I thought I would use them for my offsite backup. I am not losing much if these drives aren’t any good.
You’ve listed “sdk” as one of the drives. It has a partition of 1/2 the storage, so if that was used in the pool, that would explain the reduced storage.
To fix, simply wipe “sdk”, either by removing the “sdk1” partition or write zeros to the disk. Then retry creating the 3 x 2TByte RAID-Z1 pool again.
Assuming OP used the GUI, how did this happen?
First thing TrueNAS usually does when you setup a pool is format and partition the disks right?
A bug?
That is correct. Everything was done as shown in the screenshots above. This was a used drive so I am not surprised by the partition but I really expected TrueNAS would keep its word and destroy “all” data on the disk…
Aliens, it has to be the evil Goa’uld! At least that’s my story and I am sticking with it.
Back in reality, that is a very good question. Either the GUI should have said something like “disk already has data” because of the preexisting partition table entry and fail to use it. Or simply prompted the user to over-write it.
How can I stop these jobs? They have been stuck here ever since I tried to export the faulted test2 pool. I can’t either export test1 pool. Do I need to reboot?
I have physically removed the drives in hopes that would help but it does not seem to make a difference.
Guys! it works!!
I went ahead and rebooted to clear out those jobs since I could not find any way to stop them and they were preventing me from removing the one disk from Test1.
Removing the partitions did fix the problem.
Thanks for your help!!
If I have time (haha) I might try to reproduce the issue but currently I am thinking I probably had one of those 2TB disks in with a 1TB disk while I was doing some other testing. I am suspicious that since there was a zfs made partition there already it was not wiped.
As far as smart test go, I don’t really understand how to read them. Can I just trust TrueNAS to tell me when there is a problem with a drive or should I check the smart test results occasionally?
Thanks again for your help!
I think there is a bug somewhere there… there are also active reports at the moment of auto-expand not functioning correctly.
If the partitions are being sized wrong that would certainly explain the above.
You should check. Using this helps greatly.
You want to mainly look out for:
  • UDMA_CRC_Error_Count
  • Offline_Uncorrectable
  • Reallocated_Sector_Ct
And SMART short or long tests that cannot complete the test.
