Remove Truecharts sync in Electric Eel
I recently upgraded to Electric Eel. I didn’t remove the TrueCharts catalog prior to the upgrade and I’m getting the sync error. Is there a way to remove it from the config in Electric Eel via the Web UI or command line? Thank you for any help.
There may be a better way to do it, but you could always boot back into the Dragonfish boot environment, delete the catalog, then go back to Eel.
Is there any risk to anything booting back into that environment for this quick fix?
