Thanks for your response, Captain. Being a newbie to ZFS and TrueNAS is making this quite a learning adventure! I know the replication "wizard’ is trying to help, but it seems the basic options aren’t quite enough and the Advanced screen has so many options that it’s difficult to comprehend what they all do and how they might interact.
I don’t have any real data at risk at the moment (as far as I know!) and I do have my workaround of doing a PUSH from SysB if needed, but it would be nice have things work as intended.
It’s gotten quite late here now, but I will re-read the docs and try an experiment with restoring to the original source dataset (I created one to test with) tomorrow when I’m a little more awake. In the meantime I found the actual log file (vs the excerpts that TN displays) and discovered it had some additional interesting error messages that seem to indicate failing zfs commands. See below. [I apologize for the in-line log length, not sure if there’s some better way to post long logs, and don’t want to leave out important details]
- Note error from zfs command “missing snapshot argument”
– Looks like a zfs command failed
– Search for [shell:67] to see some interesting error messages
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /BEGIN 9519.log
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] Connecting...
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] starting thread (client mode): 0x681b1690
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Local version/idstring: SSH-2.0-paramiko_2.12.0
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Remote version/idstring: SSH-2.0-OpenSSH_9.2p1 Debian-2+deb12u3
[2025/01/26 15:47:15] INFO [Thread-186] [zettarepl.paramiko.replication_task__task_13] Connected (version 2.0, client OpenSSH_9.2p1)
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] === Key exchange possibilities ===
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] kex algos: sntrup761x25519-sha512@openssh.com, curve25519-sha256, curve25519-s
ha256@libssh.org, ecdh-sha2-nistp256, ecdh-sha2-nistp384, ecdh-sha2-nistp521, diffie-hellman-group-exchange-sha256, diffie-hellman-group16-sha512, diffie-hellman-group18
-sha512, diffie-hellman-group14-sha256, kex-strict-s-v00@openssh.com
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] server key: rsa-sha2-512, rsa-sha2-256, ecdsa-sha2-nistp256, ssh-ed25519
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] client encrypt: chacha20-poly1305@openssh.com, aes128-ctr, aes192-ctr, aes256-
ctr, aes128-gcm@openssh.com, aes256-gcm@openssh.com, aes128-cbc
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] server encrypt: chacha20-poly1305@openssh.com, aes128-ctr, aes192-ctr, aes256-
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] client mac: umac-64-etm@openssh.com, umac-128-etm@openssh.com, hmac-sha2-256-e
tm@openssh.com, hmac-sha2-512-etm@openssh.com, hmac-sha1-etm@openssh.com, umac-64@openssh.com, umac-128@openssh.com, hmac-sha2-256, hmac-sha2-512, hmac-sha1
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] server mac: umac-64-etm@openssh.com, umac-128-etm@openssh.com, hmac-sha2-256-e
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] client compress: none
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] server compress: none
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] client lang: <none>
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] server lang: <none>
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] kex follows: False
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] === Key exchange agreements ===
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Kex: curve25519-sha256@libssh.org
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] HostKey: ssh-ed25519
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Cipher: aes128-ctr
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] MAC: hmac-sha2-256
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Compression: none
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] === End of kex handshake ===
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] kex engine KexCurve25519 specified hash_algo <built-in function openssl_sha256
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Switch to new keys ...
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Got EXT_INFO: {'server-sig-algs': b'ssh-ed25519,sk-ssh-ed25519@openssh.com,ecd
sa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,sk-ecdsa-sha2-nistp256@openssh.com,webauthn-sk-ecdsa-sha2-nistp256@openssh.com,ssh-dss,ssh-rsa,rsa-sha2-256,rsa-
sha2-512', 'publickey-hostbound@openssh.com': b'0'}
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.paramiko.replication_task__task_13] Trying SSH key b'dda806d6352c1ccc835f8e14e5f37cc0'
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] userauth is OK
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Finalizing pubkey algorithm for key of type 'ssh-rsa'
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Our pubkey algorithm list: ['rsa-sha2-512', 'rsa-sha2-256', 'ssh-rsa']
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Server-side algorithm list: ['ssh-ed25519', 'sk-ssh-ed25519@openssh.com', 'ecd
sa-sha2-nistp256', 'ecdsa-sha2-nistp384', 'ecdsa-sha2-nistp521', 'sk-ecdsa-sha2-nistp256@openssh.com', 'webauthn-sk-ecdsa-sha2-nistp256@openssh.com', 'ssh-dss', 'ssh-rsa
', 'rsa-sha2-256', 'rsa-sha2-512']
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Agreed upon 'rsa-sha2-512' pubkey algorithm
[2025/01/26 15:47:15] INFO [Thread-186] [zettarepl.paramiko.replication_task__task_13] Authentication (publickey) successful!
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4138] Running ['zfs', '
get', '-H', '-p', '-t', 'filesystem,volume', 'type', 'Pool_00/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive'] with sudo=False
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.paramiko.replication_task__task_13] [chan 0] Max packet in: 32768 bytes
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Received global request "hostkeys-00@openssh.com"
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Rejecting "hostkeys-00@openssh.com" global request from server.
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Debug msg: b'/home/truenas_admin/.ssh/authorized_keys:2: key options: agent-fo
rwarding port-forwarding pty user-rc x11-forwarding'
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 0] Max packet out: 32768 bytes
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Secsh channel 0 opened.
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 0] Sesch channel 0 request ok
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4138] Reading stdout
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 0] EOF received (0)
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 0] EOF sent (0)
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4138] Waiting for exit
status
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4138] Success: 'Pool_00
/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive\ttype\tfilesystem\t-\n'
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.local] [shell:1] [async_exec:4143] Running ['zfs', 'get', '-H', '-p', '-t', 'filesystem,v
olume', 'type', 'Pool_01_Test/Dset_TestRestore_01/Dset_TestNasRep_PveBackup_Restore']
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.local] [shell:1] [async_exec:4143] Success: 'Pool_01_Test/Dset_TestRestore_01/Dset_TestNa
sRep_PveBackup_Restore\ttype\tfilesystem\t-\n'
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4144] Running ['zfs', '
list', '-t', 'filesystem,volume', '-H', '-o', 'name', '-s', 'name', '-r', 'Pool_00/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive'] with sudo=False
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.paramiko.replication_task__task_13] [chan 1] Max packet in: 32768 bytes
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 1] Max packet out: 32768 bytes
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Secsh channel 1 opened.
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 1] Sesch channel 1 request ok
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4144] Reading stdout
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 1] EOF received (1)
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4144] Waiting for exit
status
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 1] EOF sent (1)
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4144] Success: 'Pool_00
/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive\n'
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4145] Running ['zfs', '
list', '-t', 'snapshot', '-H', '-o', 'name', '-s', 'name', '-r', 'Pool_00/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive'] with sudo=False
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.paramiko.replication_task__task_13] [chan 2] Max packet in: 32768 bytes
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 2] Max packet out: 32768 bytes
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Secsh channel 2 opened.
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 2] Sesch channel 2 request ok
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4145] Reading stdout
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 2] EOF received (2)
[2025/01/26 15:47:15] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 2] EOF sent (2)
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4145] Waiting for exit
status
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4145] Success: 'Pool_00
/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive@auto-2025-01-26_14-15\n'
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4147] Running ['zfs', '
list', '-t', 'filesystem,volume', '-H', '-o', 'encryption,name', '-s', 'name', '-r', 'Pool_00/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive'] with sudo=False
[2025/01/26 15:47:15] DEBUG [replication_task__task_13] [zettarepl.paramiko.replication_task__task_13] [chan 3] Max packet in: 32768 bytes
[2025/01/26 15:47:16] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 3] Max packet out: 32768 bytes
[2025/01/26 15:47:16] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Secsh channel 3 opened.
[2025/01/26 15:47:16] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 3] Sesch channel 3 request ok
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4147] Reading stdout
[2025/01/26 15:47:16] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 3] EOF received (3)
[2025/01/26 15:47:16] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 3] EOF sent (3)
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4147] Waiting for exit
status
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4147] Success: 'aes-256
-gcm\tPool_00/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive\n'
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4149] Running ['zfs', '
get', '-H', '-p', '-t', 'filesystem,volume', 'sharesmb,mountpoint,sharenfs', 'Pool_00/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive'] with sudo=False
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.paramiko.replication_task__task_13] [chan 4] Max packet in: 32768 bytes
[2025/01/26 15:47:16] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 4] Max packet out: 32768 bytes
[2025/01/26 15:47:16] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Secsh channel 4 opened.
[2025/01/26 15:47:16] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 4] Sesch channel 4 request ok
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4149] Reading stdout
[2025/01/26 15:47:16] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 4] EOF received (4)
[2025/01/26 15:47:16] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 4] EOF sent (4)
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4149] Waiting for exit
status
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4149] Success: 'Pool_00
/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive\tsharesmb\toff\tdefault\nPool_00/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive\tmountpoint\t/mnt/Pool_00/_Dset_TestRepArch
iveNoEnc/Dset_TestRepArchive\tdefault\nPool_00/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive\tsharenfs\toff\tdefault\n'
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.local] [shell:1] [async_exec:4150] Running ['zfs', 'list', '-t', 'filesystem,volume', '-H
', '-o', 'readonly,receive_resume_token,name', '-s', 'name', '-r', 'Pool_01_Test/Dset_TestRestore_01/Dset_TestNasRep_PveBackup_Restore']
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.local] [shell:1] [async_exec:4150] Success: 'off\t-\tPool_01_Test/Dset_TestRestore_01/Dse
t_TestNasRep_PveBackup_Restore\n'
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.local] [shell:1] [async_exec:4151] Running ['zfs', 'list', '-t', 'snapshot', '-H', '-o',
'name', '-s', 'name', '-r', 'Pool_01_Test/Dset_TestRestore_01/Dset_TestNasRep_PveBackup_Restore']
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.local] [shell:1] [async_exec:4151] Success: ''
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.local] [shell:1] [async_exec:4152] Running ['zfs', 'get', '-H', '-p', '-t', 'filesystem,v
olume', 'encryption,encryptionroot', 'Pool_01_Test/Dset_TestRestore_01/Dset_TestNasRep_PveBackup_Restore']
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.local] [shell:1] [async_exec:4152] Success: 'Pool_01_Test/Dset_TestRestore_01/Dset_TestNa
sRep_PveBackup_Restore\tencryption\toff\tdefault\nPool_01_Test/Dset_TestRestore_01/Dset_TestNasRep_PveBackup_Restore\tencryptionroot\t-\t-\n'
[2025/01/26 15:47:16] INFO [replication_task__task_13] [zettarepl.replication.pre_retention] Pre-retention destroying snapshots: []
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.local] [shell:1] [async_exec:4153] Running ['zfs', 'get', '-H', '-p', '-t', 'filesystem,v
olume', 'type,mounted,mountpoint,referenced,snapdir,used', 'Pool_01_Test/Dset_TestRestore_01/Dset_TestNasRep_PveBackup_Restore']
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.local] [shell:1] [async_exec:4153] Success: 'Pool_01_Test/Dset_TestRestore_01/Dset_TestNa
sRep_PveBackup_Restore\ttype\tfilesystem\t-\nPool_01_Test/Dset_TestRestore_01/Dset_TestNasRep_PveBackup_Restore\tmounted\tno\t-\nPool_01_Test/Dset_TestRestore_01/Dset_Te
stNasRep_PveBackup_Restore\tmountpoint\t/mnt/Pool_0....ol_01_Test/Dset_TestRestore_01/Dset_TestNasRep_PveBackup_Restore\treferenced\t98304\t-\nPool_01_Test/Dset_TestRest
ore_01/Dset_TestNasRep_PveBackup_Restore\tsnapdir\thidden\tdefault\nPool_01_Test/Dset_TestRestore_01/Dset_TestNasRep_PveBackup_Restore\tused\t98304\t-\n'
[2025/01/26 15:47:16] INFO [replication_task__task_13] [zettarepl.replication.run] For replication task 'task_13': doing pull from 'Pool_00/_Dset_TestRepArchiveNoEnc
/Dset_TestRepArchive' to 'Pool_01_Test/Dset_TestRestore_01/Dset_TestNasRep_PveBackup_Restore' of snapshot='auto-2025-01-26_14-15' incremental_base=None include_intermedi
ate=False receive_resume_token=None encryption=False
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.local] [shell:1] [async_exec:4155] Running ['zfs', 'umount', 'Pool_01_Test/Dset_TestResto
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.local] [shell:1] [async_exec:4155] Error 1: "cannot unmount 'Pool_01_Test/Dset_TestRestor
e_01/Dset_TestNasRep_PveBackup_Restore': not currently mounted\n"
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4157] Running ['zfs', '
send', '-V'] with sudo=False
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.paramiko.replication_task__task_13] [chan 5] Max packet in: 32768 bytes
[2025/01/26 15:47:16] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 5] Max packet out: 32768 bytes
[2025/01/26 15:47:16] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] Secsh channel 5 opened.
[2025/01/26 15:47:16] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 5] Sesch channel 5 request ok
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4157] Reading stdout
[2025/01/26 15:47:16] DEBUG [Thread-186] [zettarepl.paramiko.replication_task__task_13] [chan 5] EOF received (5)
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4157] Waiting for exit
status
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.base_ssh] [ssh:truenas_admin@xxx.xxx.xxx.13] [shell:67] [async_exec:4157] Error 2: 'missing
snapshot argument\nusage:\n\tsend [-DLPbcehnpsVvw] [-i|-I snapshot]\n\t [-R [-X dataset[,dataset]...]] <snapshot>\n\tsend [-DnVvPLecw] [-i snapshot|bookmark] <f
ilesystem|volume|snapshot>\n\tsend [-DnPpVvLec] [-i bookmark|snapshot] --redact <bookmark> <snapshot>\n\tsend [-nVvPe] -t <receive_resume_token>\n\tsend [-PnVv] --saved
filesystem\n\nFor the property list, run: zfs set|get\n\nFor the delegated permission list, run: zfs allow|unallow\n\nFor further help on a command or topic, run: zfs he
lp [<topic>]\n'
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.paramiko.replication_task__task_13] [chan 5] EOF sent (5)
[2025/01/26 15:47:16] DEBUG [replication_task__task_13] [zettarepl.transport.local] [shell:1] [async_exec:4160] Running Pipe((['ssh', '-i', '/tmp/tmp3kqr_kxo', '-o',
'UserKnownHostsFile=/tmp/tmp5ddxs51c', '-o', 'StrictHostKeyChecking=yes', '-o', 'BatchMode=yes', '-o', 'ConnectTimeout=10', '-p22', 'truenas_admin@xxx.xxx.xxx.13', 'sh -c
\'PATH=$PATH:/usr/local/sbin:/usr/sbin:/sbin sh -c \'"\'"\'(zfs send -V -p -w -L -c Pool_00/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive@auto-2025-01-26_14-15 & PID=$!;
echo "zettarepl: zfs send PID is $PID" 1>&2; wait $PID)\'"\'"\'\''], ['zfs', 'recv', '-s', '-F', '-x', 'sharesmb', '-x', 'mountpoint', '-x', 'sharenfs', 'Pool_01_Test/D
set_TestRestore_01/Dset_TestNasRep_PveBackup_Restore']))
[2025/01/26 15:47:16] DEBUG [replication_task__task_13.async_exec_tee.wait] [zettarepl.transport.local] [shell:1] [async_exec:4160] Error 1: None
[2025/01/26 15:47:16] DEBUG [replication_task__task_13.process] [zettarepl.transport.local] [shell:1] [async_exec:4159] Error 1: "warning: cannot send 'Pool_00/_Dset_
TestRepArchiveNoEnc/Dset_TestRepArchive@auto-2025-01-26_14-15': permission denied\ncannot receive: failed to read from stream\n"
[2025/01/26 15:47:16] DEBUG [replication_task__task_13.monitor] [zettarepl.transport.local] [shell:1] [async_exec:4160] Stopping
[2025/01/26 15:47:16] ERROR [replication_task__task_13] [zettarepl.replication.run] For task 'task_13' unhandled replication error ExecException(1, "warning: cannot s
end 'Pool_00/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive@auto-2025-01-26_14-15': permission denied\ncannot receive: failed to read from stream\n")
File "/usr/lib/python3/dist-packages/zettarepl/replication/run.py", line 181, in run_replication_tasks
retry_contains_partially_complete_state(
File "/usr/lib/python3/dist-packages/zettarepl/replication/partially_complete_state.py", line 16, in retry_contains_partially_complete_state
return func()
File "/usr/lib/python3/dist-packages/zettarepl/replication/run.py", line 182, in <lambda>
lambda: run_replication_task_part(replication_task, source_dataset, src_context, dst_context,
File "/usr/lib/python3/dist-packages/zettarepl/replication/run.py", line 278, in run_replication_task_part
run_replication_steps(step_templates, observer)
File "/usr/lib/python3/dist-packages/zettarepl/replication/run.py", line 672, in run_replication_steps
replicate_snapshots(step_template, incremental_base, snapshots, include_intermediate, encryption, observer)
File "/usr/lib/python3/dist-packages/zettarepl/replication/run.py", line 713, in replicate_snapshots
run_replication_step(step, observer)
File "/usr/lib/python3/dist-packages/zettarepl/replication/run.py", line 793, in run_replication_step
ReplicationProcessRunner(process, monitor).run()
File "/usr/lib/python3/dist-packages/zettarepl/replication/process_runner.py", line 33, in run
raise self.process_exception
File "/usr/lib/python3/dist-packages/zettarepl/replication/process_runner.py", line 37, in _wait_process
self.replication_process.wait()
File "/usr/lib/python3/dist-packages/zettarepl/transport/ssh.py", line 167, in wait
stdout = self.async_exec.wait()
File "/usr/lib/python3/dist-packages/zettarepl/transport/async_exec_tee.py", line 104, in wait
raise ExecException(exit_event.returncode, self.output)
zettarepl.transport.interface.ExecException: warning: cannot send 'Pool_00/_Dset_TestRepArchiveNoEnc/Dset_TestRepArchive@auto-2025-01-26_14-15': permission denied
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< /END 9519.log
