My DataSet is using POSIX Permissions.
I am trying to resize the quota from 4TiB to 5TiB but can’t because TrueNAS keeps telling me
[EINVAL] pool_dataset_update.aclmode: Must be set to DISCARD when acltype is POSIX or OFF
I have no idea what to do. I tried to edit the Permissions to ACL but the presets say
- POSIX_OPEN
- POSIX_RESTRICTED
- POSIX_HOME
- POSIX_ADMIN
and choosing one obviously will not get me a proper ACL-Permission-Set. I am not sure but changing from POSIX to ACL does not seem to be an option. All I want to do is change the quota for the one DataSet. I hope somebody will be able to help me.
Thanks in advance!
Full Error Message
error
VALIDATION
remove_circle_outline
More info…
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 198, in call_method
result = await self.middleware.call_with_audit(message[‘method’], serviceobj, methodobj, params, self)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1466, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1417, in _call
File “/usr/lib/python3/dist-packages/middlewared/service/crud_service.py”, line 189, in update
return await self.middleware._call(
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1417, in call
File “/usr/lib/python3/dist-packages/middlewared/service/crud_service.py”, line 210, in nf
rv = await func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 47, in nf
res = await f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 187, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool/dataset.py", line 856, in do_update
verrors.check()
File “/usr/lib/python3/dist-packages/middlewared/service_exception.py”, line 70, in check
raise self
middlewared.service_exception.ValidationErrors: [EINVAL] pool_dataset_update.aclmode: Must be set to DISCARD when acltype is POSIX or OFF
