Restoring connection to pool
I accidentaly reset my configuration to it’s default settings. That was not what I intended to do, but i’m on my way to restore the setup. I just can’t seem to complete it. I’ve imported the data pool with its partitions. I’ve added a new user which I then gave permission to connect to the pools but I still can’t connect to the drives from my pc.
i’m a bit rusty in the truenas environment because I set it up and just used it for connecting to from time to time. When I couldnt connect I reset to default and this all happened.
Can someone help me?
thanks in advance.
Did you create a share?
I did not do that. Now i did do that, and I can connect to the folders, but they appear to be empty.
When I make the share I see all these dropdowns to the folders I put in the root folder I want to connect to, but when I connect to it, the contents of the folder don’t appear.
fixed. I added the permissions of the newly made user recursively. Thanks for the help!
