First, it’s worth noting that A.R.M. didn’t work with /dev/sr0, and I had to add /dev/sg10 as well.
The initial stage worked, and the transcode is in progress. BUT… it’s not using my Nvidia 5060. Can anyone suggest why? My 5060 works great with ollama, and I have the drivers installed via the checkbox. I have the GPU reserved, and ARM is the only app container running. Is this a simple matter that the App Store “A.R.M.” container is missing the required bits and bobs?
user_config.yaml snippet:
“resources”:
“gpus”:
“kfd_device_exists”: false
“nvidia_gpu_selection”:
“0000:01:00.0”:
“use_gpu”: true
“uuid”: “GPU-3099565f-91e4-61a7-4459-15c721c290bd”
“use_all_gpus”: false
“limits”:
“cpus”: 2
“memory”: 4096
Log:
[12-27-2025 16:43:46] INFO ARM: ************* Starting Transcode With HandBrake *************
[12-27-2025 16:43:46] INFO ARM: Starting Handbrake for MKV files.
[12-27-2025 16:43:46] INFO ARM: Transcoding file title_t02.mkv to '/home/arm/media/transcode/unidentified/Blade Runner Branch_176687273806/title_t02.mkv'
[16:43:46] Compile-time hardening features are enabled
[16:43:46] nvenc: version 13.0 is available
[16:43:46] nvdec: is not compiled into this build
[16:43:48] CUDA Version: 12.0
[16:43:48] vcn: not available on this system
[16:43:48] hb_qsv_make_adapters_list: MFXVideoCORE_QueryPlatform failed impl=0 err=-16
[16:43:48] qsv: is available on this system
[16:43:48] hb_init: starting libhb thread
[16:43:48] thread 7f18b77fe640 started ("libhb")
HandBrake 1.10.2 (2025100400) - Linux x86_64 - https://handbrake.fr
16 CPUs detected
Opening /home/arm/media/raw/Blade Runner Branch/title_t02.mkv...
[16:43:48] CPU: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
