Rsync connection refused : scale to scale
Home user - there is one user on the box
Trying to set up a simple Rsync pull from my main TrueNAS Server to the backup both are TrueNAS-SCALE-24.10.2
Mainserver has Rsync daemon installed
Max connections = 4
Module Name = huge-backup
Host Path - /mnt/Vault/Huge
RO
Max conn = 0
UID = 0
GID = 0
Host network unticked
Says running
Ports
tcp://0.0.0.0:30026:30026
tcp://:::30026:30026
A port scan show 30026 is open
log
025-03-08 20:19:56.829033+00:002025/03/08 20:19:56 [1] rsyncd version 3.2.7 starting, listening on port 30026
2025-03-08 20:31:45.242151+00:002025/03/08 20:31:45 [498] rsync: [Receiver] getpeername on fd4 failed: Transport endpoint is not connected (107)
2025-03-08 20:31:45.242228+00:002025/03/08 20:31:45 [498] rsync error: error in socket IO (code 10) at clientname.c(326) [Receiver=3.2.7]
Remote System
Remote Host is correct
Module name was copied & pasted
user truenas_admin
Direction Pull
Error
rsync: [Receiver] failed to connect to 192.168.1.200 (192.168.1.200): Connection refused (111)
rsync error: error in socket IO (code 10) at clientserver.c(139) [Receiver=3.2.7]
Solved
Changed port in rsync Daemon to 873
