So after updating to 24.10 I can no longer switch dataset SMB share Enabled state in /ui/sharing/smb - it does nothing at all.
However on /ui/sharing, where the list is collapsed, it works fine, but there I can access only the first four shares:
Any insight?
Force reload the page to see if it helps.
You can also try a different browser.
Nothing helped. Same behaviour when on Android phone and on Windows desktop via Chrome
I just now noticed the notice, which was added just two days ago, and I upgraded 3 days ago
For now rolled back to Dragonfish-24.04.2.3 and everything works just fine
Not sure though if this is related to the mentioned SMB issue. Doesn’t look like it is, but I’ll stick around with Dragonfish for the time being
As suspected, still the same on ElectricEel-24.10.0.2
You could possible try to remove and recreate one of the shares.
Failing that I would post a proper bug report.
Same with new shares. Created an issue
Apparently it’s been fixed and will be released with 24.10.1 (planned date 2024-12-09 I believe)
My issue was a duplicate of this one
I trust this will work as expected, so marking this as resolved
