[Read Notice] TrueNAS SCALE 24.10.0.1 and 24.04.2.4 are Now Available!
Important Notice: In fixing the one SMB issue, we may have exposed another. If you are a heavy SMB user please do not update until we’ve had time to diagnose. We are investigating and expect to have a resolution in the near future. Thanks!
We are pleased to release TrueNAS SCALE 24.10.0.1 and 24.04.2.4!
These releases address a small number of issues discovered in the 24.10.0 and 24.04.2.3 releases.
Notable Changes in 24.10.0.1:
  • Fix memory consumption related to SMB AIO reads (NAS-132166).
  • Fix disk.sync_all edge-case crash (NAS-132177).
  • Fix libzfs errors in py-libzfs in electric eel are out of sync with libzfs (NAS-132126).
  • Prevent empty critical bond interfaces on TrueNAS Enterprise HA systems (NAS-132187).
  • Fix HA logic bug to ensure marked critical interfaces are treated as critical (NAS-132115).
  • Prevent SED pool degradation after power loss (NAS-129366).
  • Fix TrueNAS ES24 enclosure management bug (NAS-132067).
See the 24.10.0.1 Release Notes for more details.
Notable Changes in 24.04.2.4 :
See the 24.04.2.4 Release Notes for more details.
24.10.0.1 Changelog: https://www.truenas.com/docs/scale/24.10/gettingstarted/scalereleasenotes/#241001-changelog
24.04.2.4 Changelog: https://www.truenas.com/docs/scale/24.04/gettingstarted/scalereleasenotes/#240424-changelog
Download : https://www.truenas.com/download-truenas-scale
24.10.0.1 Documentation : https://www.truenas.com/docs/scale/24.10
24.04.2.4 Documentation : https://www.truenas.com/docs/scale/24.04
Thank you for using TrueNAS SCALE! As always, we appreciate your feedback!
Just to restate from my “pre-heating” thread, while we had expected and planned for 24.04.2.3 to be the final Dragonfish release, the fixes here are being published for both branches to ensure the stability of our Conservative and Mission Critical SCALE users.
Electric Eel has had an incredible uptake speed with over 25,000 installs in just under ten days - new TrueNAS users should start with 24.10 to take advantage of the general system improvements. Existing Dragonfish users with a need for the improved feature set of RAIDZ expansion, Docker-backed Apps, and other improvements should consider moving to 24.10 after reviewing the upgrade notes to understand the Kubernetes to Docker migration and ensure a smooth upgrade.
just tried installing the update and on reboot im getting a kernel panic error? its strange…might just rollback for now but i also did notice i had a boot-pool error saying it was degraded, dont know how or why, but was hoping it was just a bug as all my drives have run well and never any errors on tests before…
but hopefully its not an issue with the update?
edit: the first error shows as a checksum verification error just for added info…yeah and 24.10.0.0 load perfectly fine for me
@techdan91 did you update from 24.04.2.3 or 24.10.0?
We performed two upgrades this morning, and it went well.
I hope it is not a disk issue. If you can roll back, can you check that your boot-pool is healthy?
You might also want to perform a S.M.A.R.T test.
I updated this morning and while the update was successful, every time I tried to write data, it would randomly cause the system to panic and reboot. I had to revert back to 24.10.0 to stop it from rebooting during writes.
Can’t see anything in the update that would seem to be related to that issue, it was a relatively small amount of changes. A bug ticket, debug and further details on the type of workload would be super helpful.
While the update was successful, there may be something wrong with SMB with the update from 24.04.2.3 → 24.04.2.4. Linux can see the shares in the file manager and work with them, but the shares have disappeared from the file managers network section from all windows 10 and windows 11 computers. Mapping a drive works and they are accessible from there
I don’t see anything obvious and no obvious errors. Ping by ip or by name works fine as does ssh.
Similiar issue here too after updating. When there are smb reads it goes in kernel panic and restarts. Tried couple times and it happened almost constantly.
System supermicro x12 STL
Cpu intel xeon E 2314
64gb ecc
2 pools
Pool 1 ----2 ssd’s in mirror Samsung 990pro 1 tb
Pool 2 — 2 vedvs 6x16tb z2 wd ultrastar ---- and 4x4 tb z2 hgst nas drives
Reverted back to initial release
After upgrade, copying file from SMB to local will result in ‘network error’ or ‘invalid signature’
Then the dashboard’s notifications will say
Core files for executables have been found in /var/db/system/cores/...... etc.
There was multiple core.smb**(can’t remember)**.zest files which I presume are dumps.
I’m on a schedule hence I have to revert the upgrade without troubleshooting in detail.
Didn’t realize this update had some out today, finally went to update from 24.04 to 24.04.2.3 and had all sorts of problems with SMB/CIFS shares, rolled back to 24.04 and all is working again. Started to search and saw this release today, and checked the boot environment and sure enough, it had updated to 24.04.2.4. SMB reads and writes were failing, TrueNAS would panic and reboot.
Interesting, we are investigating.
Updated from 24.04.2.3 to 24.04.2.4.
Luckily no kernel panic or network error with SMB transfer here, but catastrophic transfer performance (maximum transfer of around 1MB/sec with drops to a few bytes/s).
Rollback solved the problem. There is clearly a problem around SMB.
If TrueNAS didn’t panic and reboot anything utilizing the SMB/CIFS share would essentially lock. I only use TrueNAS to host an SMB share with all of my media on it, everything else I use a separate machine for. Plex would start to play an item and within 10 seconds it would just sit buffering because it couldn’t read anymore. SabNZBd would start a download and then lock up and become unresponsive and I would be forced to reboot the host running the Sab container. If it did manage to remain responsive the downloads would fail as “corrupt”.
After updateing my system hangs at NMI Watchdog: Enabled Permanently consumes one hw-PMU counter :confused:
If someone can reproduce the reboot issue, please send me a private message so that I can investigate.
I recommend people don’t update their systems to these hot-fix releases until the NEW SMB issue is understood and probably resolved.
Yeah I updated and was met with a borked install. Re-installed 24.10 RC2.
I have fix candidate for 24.10.0.1 SMB reboot issue, but need someone who can reliably reproduce it. If you can reproduce and are willing to test the fix, please send me a private message and I’ll provide files and instructions on how to install.
Can I just say that the release notes link from the webapi is not helpful. It points to a long document for 24.10 with no indication about what changed in 24.10.0.1.
Perhaps a better link would be this.
And perhaps there should be a line at the top can says “For incremental changes that have occurred in this series look here”
I updated from ElectricEel-24.10.0 to ElectricEel-24.10.1 and after reboot, all my Dockers apps were not shown.
There was a notification that nvidia.github.io was not reachable or something, I didn’t bother to investigate much, I just used the ElectricEel-24.10.0 boot and restarted. So now I’m back on ElectricEel-24.10.0.
Sorry that I didn’t gather much info while having issues, but I didn’t have time to have my stuff offline.
