Scale Created Special Meta Device Non-Mirrored
Hey there truenas community.
I messed up while creating my special metadata device and created 2 individual metadata devices instead of a mirrored group of the two disks. The output of zpool status looks like this:
root@RussNAS[~]# zpool status
  pool: RussNAS
 state: ONLINE
  scan: scrub in progress since Sat Jul 20 05:56:20 2024
        7.47T / 11.6T scanned at 12.7G/s, 196G / 11.6T issued at 332M/s
        0B repaired, 1.65% done, 10:01:19 to go
        NAME                                      STATE     READ WRITE CKSUM
        RussNAS                                   ONLINE       0     0     0
          raidz1-0                                ONLINE       0     0     0
            2055ecd8-a72c-4de9-8967-f24f55a1803e  ONLINE       0     0     0
            c4bf8996-ffd3-44f5-8189-cc12553b6e0b  ONLINE       0     0     0
            35f310a4-bb76-4d57-bd00-a7373532fa81  ONLINE       0     0     0
        special
          f28424a5-058e-479e-821b-4285f4e32400    ONLINE       0     0     0
          4b18294a-758d-4a9f-9847-fa2d701a95b2    ONLINE       0     0     0
errors: No known data errors
I’m pretty new to ZFS and Truenas, and could use some guidance on how to fix this. Using the GUI when I try to offline either of the Disks I get an error saying that there are no valid replicas (which make sense because the disks aren’t in a mirror).
Any help would be appreciated.
You can only destroy and recreate the pool from scratch in order to address this issue.
Unless special vdevs are handled in a special way, it should be possible to zpool remove one of the drives, if not from GUI then from CLI, and then add it back to extend the remaining drive into a mirror.
Having a backup is highly advisable… which makes “backup-destroy-restore” a straightforward option.
I thought only L2ARC and SLOG vdevs could be safely removed this way.
You can’t remove the entire vdev this way. But I agree that you should be able to remove one device from the vdev.
Oops! Possible brain fart here. We should be able to remove devices in stripes… if the pool is all mirrors. The raidz1 data vdev probably prevents any removal here.
Thanks for the response, I have about ~1.5tb already loaded that I actually care about and doesn’t change often so as a simple backup and safety measure I’ll just copy that data over to a hard drive I still have on another desktop so I don’t risk losing it.
I also have hourly, daily, and weekly snapshots going back for about 2 weeks but I’m not sure how useful those would be in the event of a destroy. I’m assuming those snapshots would also be destroyed / couldn’t be used for a restore?
If I were to use the GUI would rough steps be:
  1. Click “Export / Disconnect”
  2. Check “Destroy Data on This Pool”
  3. Uncheck “Delete saved configurations from TrueNAS”
  4. Click “Confirm Export / Disconnect”
  5. Create new Pool from scratch with same RaidZ1 setup + correct mirrored metadata devices
  6. Re-create my datasets, apps, etc.
Appreciate the checking of the above steps.
I also have SSH access setup, so can run CLI commands without hooking up a keyboard and monitor to the NAS / copy + paste, but obviously am more comfortable clicking buttons on the GUI.
Are you sure you need the metadata vdev? And your needs couldn’t be served by, say, metadata-only L2ARC? Because the latter would not be critical to your pool as is the former.
For the sake of future learning (and if you’re going to destroy the pool anyway), see if you can zpool remove one of the metadata devices then add it back as a mirror. Might save you a fair bit of time and would be good to know if possible. I would assume so as it should just evacuate data to the remaining device.
In your case it would be zpool remove RussNAS 4b18294a-758d-4a9f-9847-fa2d701a95b2
Continue with the backup first though, because everyone should have a backup!!!
Also agree on this point, doing it this way will remove the points of failure introduced with metadata vdevs (that is, if you need them at all?).
This is really a case of needing the OP to post their complete hardware, software and pools setups. The description is perfectly fine if this was just a TrueNAS machine to learn all the features and data doesn’t matter.
Otherwise, :triangular_flag_on_post: :triangular_flag_on_post: :triangular_flag_on_post:
Multiple red flags thrown up
Next time, consider making a “checkpoint” before you do major pool operations.
Sure thing find bellow full hardware specs, software details, and pool outputs. For the most part yes this TureNAS machine is for learning and the none of the data is “critical”.
Hardware:
    CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
    Motherboard: Gigabyte Z390 AORUS PRO
    RAM: 128GB (4x32GB Sticks) DDR4 3600 (PC4-28800) C181.35V
    Network: 10G Dual RJ45 Port PCI-E Network Card Gigaplus X540-T2 (Only one port in use)
    Disks:
        Hard Drives:
            3x Seagate Ironwolf 12TB
        Solid States:
            2x Samsung SSD 850 EVO 500GB
        NVME (Boot Drive):
            1x Western Digital 500GB WD Blue SN570
Software:
    Truenas Scale Version: Dragonfish-24.04.2
    Datasets: (Lots under ix-applications / apps but censored for brevity)
        NAME                     USED  AVAIL  REFER  MOUNTPOINT
        RussNAS                  7.74T  13.9T  24.3G  /mnt/RussNAS
        RussNAS/apps             9.71G  13.9T   110M  /mnt/RussNAS/apps
        RussNAS/ix-applications  5.70G  4.30G   704K  /mnt/RussNAS/ix-applications
        RussNAS/media            1.28T  3.76T  1.24T  /mnt/RussNAS/media
        RussNAS/scripts          5.40M  9.99G  5.40M  /mnt/RussNAS/scripts
        RussNAS/windowsbackups   6.42T  6.40T  5.60T  /mnt/RussNAS/windowsbackups
    SMB Shares:
        Name            Path
        windowsbackups  /mnt/RussNAS/windowsbackups
        media           /mnt/RussNAS/media
        scripts         /mnt/RussNAS/scripts
    Snapshots:
        media:
            2024-07-20-14-00-08-EDT - INFO - 25 hourly snapshots found for RussNAS/media
            2024-07-20-14-00-10-EDT - INFO - 14 daily snapshots found for RussNAS/media
            2024-07-20-14-00-10-EDT - INFO - 2 weekly snapshots found for RussNAS/media
        windowsbackups:
            2024-07-20-14-00-03-EDT - INFO - 25 hourly snapshots found for RussNAS/windowsbackups
            2024-07-20-14-00-05-EDT - INFO - 14 daily snapshots found for RussNAS/windowsbackups
            2024-07-20-14-00-06-EDT - INFO - 2 weekly snapshots found for RussNAS/windowsbackups
    Apps:
        App Name            Catalog Status
        jellyfin            TrueNAS Stopped
        mineos              TrueNAS Stopped
        nginx-proxy-manager TrueNAS Stopped
        pihole              TrueNAS Running
        plex                TrueNAS Running
        tautulli            TrueNAS Running
        wg-easy             TrueNAS Running
Pool Setup:
    root@RussNAS[~]# zpool list
    NAME        SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP    HEALTH  ALTROOT
    RussNAS    33.6T  11.6T  22.0T        -         -     0%    34%  1.00x    ONLINE  /mnt
    boot-pool   448G  5.23G   443G        -         -     0%     1%  1.00x    ONLINE  -
      pool: RussNAS
     state: ONLINE
            11.6T / 11.6T scanned, 11.4T / 11.6T issued at 605M/s
            0B repaired, 98.49% done, 00:05:03 to go
            special
      pool: boot-pool
     state: ONLINE
      scan: scrub repaired 0B in 00:00:04 with 0 errors on Thu Jul 18 03:45:05 2024
            boot-pool    ONLINE       0     0     0
              nvme0n1p3  ONLINE       0     0     0
LMK if there are any details that I missed
This is a really great feature I was unaware of, and will definitely take advantage of. Thank you
Because of the raidz data vdev, you won’t be able to remove either special disk (as it’s effectively two single-disk vdevs)
Hopefully you are able to back things up and restore.
TBH I’m not sure.
When I had much less RAM (32gb) I had configured the 2x 500gb SSD’s as L2ARC and noticed that there was always a significant % of my RAM free which obviously is not ideal.
My workload consists of storing 4k60fps Drone Videos, torrents, and taking windows backups using the built in windows 7 backup tool. I also run some apps.
Two problems there: first, 32 GB of RAM isn’t close to enough to make use of L2ARC; second, earlier versions of SCALE would use at most half of RAM for ARC. Dragonfish largely resolves the latter, and 128 GB of RAM is a good amount.
Thanks for the listing. That helps sort out a lot of problems when reading posts
Just for posterity, running zpool remove for either disk returns the following error:
root@RussNAS[~]# zpool remove RussNAS f28424a5-058e-479e-821b-4285f4e32400
cannot remove f28424a5-058e-479e-821b-4285f4e32400: invalid config; all top-level vdevs must have the same sector size and not be raidz.
root@RussNAS[~]# zpool remove RussNAS 4b18294a-758d-4a9f-9847-fa2d701a95b2
cannot remove 4b18294a-758d-4a9f-9847-fa2d701a95b2: invalid config; all top-level vdevs must have the same sector size and not be raidz.
As for the future of the thread, my media has been backed up so will just kiss my windows backups goodbye and recreate the pool which isn’t the end of the world for me but a lesson learned. Thanks for all those that chimed in.
