How is even possible? See the Scrub in Progress… -2 hours and 117.30% progress. I’ve been using FreeNAS / TrueNAS for over a decade. First time seeing this. TrueNAS 25.10.6 - Goldeye
System: Supermicro X10 SLH-F, 32GB ECC RAM, Xeon E3-1230v3.
seen that when the scrub progress counter wraps or the eta math goes negative after a restart / long pause. the scrub itself is usually fine. the ui just lost the start timestamp.
from shell:
zpool status -v
zpool get all | grep -i scrub
if status still says scrub in progress with a sane scanned %, ignore the -2h / 117% banner until it finishes. if status says none and the ui still shows scrubbing, refresh or restart middlewared once.
paste the zpool status scrub lines if it stays stuck past finish.
Restarted middleware and the scrub has indeed finished. Thank you.
Strange bug and I can understand how it can happen. But never had this in all the years running TrueNAS.
