Serial Numbers Don't Match Disks
I’m still relatively new to all this, but have been running my server on an old desktop build for about a year with just a couple minor issues that I attributed to using old hardware.
Recently, I’ve been running into issues with a SATA SSD pool. It is 2 T-Force Vulcan Z 256GB SATA ssds in a mirror purchased back in March from Newegg (Sold by Newegg, not a marketplace seller so should be legit) as they had a great deal going on. Earlier this summer, I was getting a ton of read and write errors on one of the drives. I was able to identify the problem drive and swapped it with the spare I (thankfully) purchased. The bad drive went back to Teamgroup for warranty, and they sent a replacement.
Now, I’m dealing with another drive that is having issues. Storage>Pool>Manage Devices shows the one vdev in the Pool as degraded with one disk marked as “Unavailable”
“Ok, cool, let’s just check which physical disk is bad and replace it then jump through warranty again”
I go to check the serial number of the one still good (process of elimination says it’s the other one that would be bad), and the serial number showing in Disks and when running smartctl in the shell does not appear anywhere on the physical drive. The number matches a pattern shown above the UPC instead of the pattern of the s/n line printed on the disk, but it doesn’t match anything on either of the disks I have installed.
Even weirder is that the Storage>Disks view shows both drives in the Pool and I can grab SMART details from both disks just fine.
Even more things I don’t understand is that it looks like the bad disk is now showing as an unused disk, but I can’t use it to replace itself (I get an error about “One or more CRCs don’t match” indicating that the Replace functionality expects the replacement disk to be empty).
So I’m looking for help in how to proceed.
  1. How do I find the bad drive with the S/N’s being incorrect?
  2. While the disk may be at fault, I don’t see any actual errors noted in the detailed SMART test results so is there something else going on and I can save this disk?
Note: Both of the disks in this pool are connected to SATA ports on the motherboard. They don’t go through my HBA.
Thank you!
Bad disk SMART details
admin@truenas[~]$ sudo smartctl -x /dev/sdf
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.12.15-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:     T-FORCE 256GB
Serial Number:    TPBF2412030030104579
Firmware Version: X0219B0
User Capacity:    256,060,514,304 bytes [256 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available
Device is:        Not in smartctl database 7.3/5804
ATA Version is:   ACS-2 T13/2015-D revision 3
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Aug 24 15:00:48 2025 CDT
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Disabled
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
Wt Cache Reorder: Unavailable
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
No failed Attributes found.
General SMART Values:
Offline data collection status:  (0x02) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  120) seconds.
capabilities:                    (0x11) SMART execute Offline immediate.
                                        No Auto Offline data collection support.
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        No Selective Self-test supported.
SMART capabilities:            (0x0002) Does not save SMART data before
                                        entering power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (  10) minutes.
SCT capabilities:              (0x0001) SCT Status supported.
SMART Attributes Data Structure revision number: 1
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     -O--CK   100   100   050    -    0
  5 Reallocated_Sector_Ct   -O--CK   100   100   050    -    0
  9 Power_On_Hours          -O--CK   100   100   050    -    2542
 12 Power_Cycle_Count       -O--CK   100   100   050    -    18
160 Unknown_Attribute       -O--CK   100   100   050    -    0
161 Unknown_Attribute       PO--CK   100   100   050    -    100
163 Unknown_Attribute       -O--CK   100   100   050    -    7
164 Unknown_Attribute       -O--CK   100   100   050    -    32911
165 Unknown_Attribute       -O--CK   100   100   050    -    109
166 Unknown_Attribute       -O--CK   100   100   050    -    1
167 Unknown_Attribute       -O--CK   100   100   050    -    20
168 Unknown_Attribute       -O--CK   100   100   050    -    5050
169 Unknown_Attribute       -O--CK   100   100   050    -    100
175 Program_Fail_Count_Chip -O--CK   100   100   050    -    0
176 Erase_Fail_Count_Chip   -O--CK   100   100   050    -    0
177 Wear_Leveling_Count     -O--CK   100   100   050    -    0
178 Used_Rsvd_Blk_Cnt_Chip  -O--CK   100   100   050    -    0
181 Program_Fail_Cnt_Total  -O--CK   100   100   050    -    0
182 Erase_Fail_Count_Total  -O--CK   100   100   050    -    0
192 Power-Off_Retract_Count -O--CK   100   100   050    -    16
194 Temperature_Celsius     -O---K   100   100   050    -    24
195 Hardware_ECC_Recovered  -O--CK   100   100   050    -    0
196 Reallocated_Event_Count -O--CK   100   100   050    -    0
197 Current_Pending_Sector  -O--CK   100   100   050    -    0
198 Offline_Uncorrectable   -O--CK   100   100   050    -    0
199 UDMA_CRC_Error_Count    -O--CK   100   100   050    -    0
232 Available_Reservd_Space -O--CK   100   100   050    -    100
241 Total_LBAs_Written      ----CK   100   100   050    -    44187
242 Total_LBAs_Read         ----CK   100   100   050    -    5269
245 Unknown_Attribute       -O--CK   100   100   050    -    84609
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x24       GPL     R/O     88  Current Device Internal Status Data log
0x25       GPL     R/O     32  Saved Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Short offline       Completed without error       00%      2541         -
# 2  Short offline       Completed without error       00%      2517         -
# 3  Short offline       Completed without error       00%      2493         -
# 4  Short offline       Completed without error       00%      2469         -
# 5  Short offline       Completed without error       00%      2445         -
# 6  Short offline       Completed without error       00%      2421         -
# 7  Short offline       Completed without error       00%      2397         -
# 8  Extended offline    Completed without error       00%      2375         -
# 9  Short offline       Completed without error       00%      2373         -
#10  Short offline       Completed without error       00%      2349         -
#11  Short offline       Completed without error       00%      2325         -
#12  Short offline       Completed without error       00%      2301         -
#13  Short offline       Completed without error       00%      2276         -
#14  Short offline       Completed without error       00%      2252         -
#15  Short offline       Completed without error       00%      2228         -
#16  Extended offline    Completed without error       00%      2207         -
#17  Short offline       Completed without error       00%      2204         -
#18  Short offline       Completed without error       00%      2180         -
#19  Short offline       Completed without error       00%      2156         -
Selective Self-tests/Logging not supported
SCT Status Version:                  3
SCT Version (vendor specific):       0 (0x0000)
Device State:                        Active (0)
Current Temperature:                    24 Celsius
Power Cycle Min/Max Temperature:     24/24 Celsius
Lifetime    Min/Max Temperature:     19/33 Celsius
Specified Max Operating Temperature:   100 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Data Table command not supported
SCT Error Recovery Control command not supported
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4              18  ---  Lifetime Power-On Resets
0x01  0x010  4            2542  ---  Power-on Hours
0x01  0x018  6      2895876526  ---  Logical Sectors Written
0x01  0x020  6       132382095  ---  Number of Write Commands
0x01  0x028  6       345348757  ---  Logical Sectors Read
0x01  0x030  6         2367632  ---  Number of Read Commands
0x07  =====  =               =  ===  == Solid State Device Statistics (rev 1) ==
0x07  0x008  1               0  ---  Percentage Used Endurance Indicator
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  4            1  Command failed due to ICRC error
0x0002  4            1  R_ERR response for data FIS
0x0005  4            1  R_ERR response for non-data FIS
0x000a  4            4  Device-to-host register FISes sent due to a COMRESET
Disk Page
System Info
TrueNAS SCALE: 25.04.0
Motherboard: ASROCK X370 Killer SLI/ac
Bios: P7.10
CPU: Ryzen 5 1600
RAM: G-Skill TridentZ 16GB (2x8) DDR4-3200
HBA: LSI 9207-8i
Network: Generic Intel I226-V 2.5Gb ethernet
I do not follow what you are saying. The first part you say you found a match, pattern above the UPC? And then you say there is no match on the drives. Which one is it?
The SMART FAILED message indicates some selftest failed. If the drive is working, pull all the data off you can before it becomes inoperable.
If you do not actually know which drive it is, you can Resilver / Replace one drive while the suspect one is still connected, and once you remove the suspect drive, then you can verify it was the FAILED unit. If you can just remove the drive without any data loss, do that. Unfortunately you did not tell us the configuration of your pool(s).
The pattern of the system-reported serial number matches a string that is printed above the UPCs on these drives, starts with "TPBF-[9 numbers]-[1 number]-[6 numbers] but does not match the value on either of the drives I have installed. The system-reported serial number also doesn’t match the numbers on the specific field labelled “S/N” on the drives.
I noted in my post that this is a mirror, but I can also clarify that it’s just a 2 disk mirror. I’m trying to figure out which of the 2 is the bad one so I can swap my spare in and send the bad one out for a warranty replacement. I am struggling to figure out which one is the problem drive. All the posts I’ve read say to look for the serial number reported in the system then look at the physical drive.
Is there a way to see which SATA port number (via the motherboard) each drive is plugged into? I haven’t found a way to do that.
Thank you
Sorry, I missed the mirror even though I did read it.
Since it is a mirror, shutdown, remove one drive and if you can connect it to a different computer to look at the SMART data to see if it is the failed one.
Once you have identified the bad one, make sure you mark the good one with the last four characters of the serial number for future use.
You purchased not a very great brand of drive. They are the least expensive for a reason. I am surprised that the casing does not have the actual serial number listed. Out of pure curiosity, could the snap a photo of both sides of the drive, I’d like to see where they messed up.
Pulling one at a time and using a sata to usb adapter I have helped me track down the problematic drive. I’ve replaced (so much easier with the gui replace function) and resilvered and now the pool is healthy again. Thank you!
On my Windows machine, the Serial Number reads off the same as TrueNas: TPBF-2412030030-1-04579. This holds true even when using Teamgroup’s own S.M.A.R.T tool (grabbed it on theory they were doing something custom).
Here’s the photos of the problematic drive that is providing the above Serial in system.
Back of Drive
Front of Drive
Even the new one provided by Teamgroup’s warranty replacement reports a different serial than is printed. These numbers that start with “TPBF” do not register as serial numbers on TG’s warranty site, but the actual serial printed on the drive does.
This should tell you a little about their Quality Control.
But, the benefit of the doubt is: This drive is not listed in the smartmontools database. Maybe the serial number is there, just in a non-standard location. The Device Model is wrong as it is the manufacturer. But I say again, Quality Control.
Apparently this cropped up last year on the freebsd forums… I didn’t read through all the details of the thread.
https://forums.freebsd.org/threads/serial-number-as-read-by-dmesg-8.94461/
its interesting, couple of theories purely from my brain:
  1. they rebadge other manufacturers.
  2. its a type of way to know when someone is messing around with the smartctl data… if they have an internal database of internal serials matching external, then the people who are re-birthing drives would have a hard time to know the internal serial number
  3. poor QA and laziness on the manufacturers part…
  4. Something Ive not thought about…
For anyone who comes across this in the future:
I resolved this fully by just purchasing some higher quality drives (used enterprise Micron drives). I’ll end up repurposing these cheap junk ssds to some homelab throwaway projects.
The T-Force ssds wouldn’t stay stable. They seem to work ok as single standalone drives in a Windows machine I set up for my kids to use.
I’m just going to stick to the more reputable manufacturers - and honestly used enterprise stuff has been better to me than new consumer grade anyways.
