I recently moved over to scale and decided to try sonarr. I’ve set up everything as I needed it, I can search files and they successfully go to my transmission server and download. My transmission server is set up on a separate core install (long story, it’s how I know it works how I need it to) and it sends the torrents and everything is good there. However, once the file is done, it cannot copy it. I can import all the files from my TV dataset and I’ve created a Sonarr group with the 351 id I saw someone say somewhere. I’ve added apps to that group as well as my user just in case. I’ve set up an ACL to give the Sonarr and apps groups full control. I’ve set the permissions of the whole thing to 775. I’ve set up an remote path linking the remote transmission download folder to a local directory on the dataset. I’m assuming this is a permissions issue but who knows at this point. If anyone could give me some guidance I’d appreciate it.
Thanks!
