Synology Ds1621xs+
Hi
I’m beginner … I apology…
I’ve a Synology ds1621xs+ Nas. I don’t have vidéo port on Nas and i wish install Truenas.
How can i do to get a screen ?
How can i do to access bios of the nas to boot from a USB key ?
Thanks you for your help
I don’t believe the ds1621xs+ has a free pcie slot where you could install a cheap gpu for video output, at least i couldn’t see one mentioned on the specc sheet. Open up the case and see if it has a free slot, or if by any chance the 10gig network adapter is an external card you could remove unil you’ve finished the setup and are certain that truenas boots.
In addition the specc sheet mentioned that it only has 8gb of ram, which is the bare minimum for basic truenas operation. If you plan to run anny apps you should upgrade it to 16 or 32gb which is the maximum according to the specc sheet.
OP has a post in French - International section, if that is more helpful. Wasn’t sure if language is barrier or not
