Tailscale says IP forwarding is disabled
Requesting some assistance from the TrueNAS gurus out here. I’m working on setting up TailScale and I have it installed on my two systems (specs noted in my signature below). The two machines are identical hardware and installs as far as TrueNAS goes. I have read in the forums that ip forwarding is enabled already but as the tag says Tailscale is telling me that it is not only on one of my systems.
My second system does not give me the error above.
I have even tried to manually enable ip forwarding by adding the sysctl entries for it mentioned by several people on the forums.
Hoping someone on here can help me figure this out.
