Tailscale stuck on deploying!?
I have two systems one of which is at my house and a second which is offsite. I’ll list the specs below.
#1 Main System - Asus W680 with 128gb of ecc ram running a 13900ks.
#2 Backup System - Asus B850-I with 64gb of ecc ram running a ryzen 5 7600.
Tailscale installed on the main system and deployed with no problems but its stuck on deploying on the backup system. I have reinstalled Tailscale several times and I also did several fresh installs on TrueNas Community Edition with no results. Anyone having this issue?
in the setup the Auth once checkbox should be checked.
Make sure the userspace checkbox is not checked in the app setup. That will keep it from deploying.
Also, you may have to redo the auth key in the truenas setup with a new auth key from your Tailscale admin page if the app won’t deploy.
Other than that, it should just work I have had no issues for quite awhile with Tailscale and Truenas and I am running the latest version of the app on both systems.
Anyone out there? I’d be extremely appreciative if anyone could even point me in the right direction. Thanks in advance,much appreciated!
