Testing TrueNAS with a Vagrant box -- before I buy very expensive hardware, I want to see the UI
Hi
I found
https://app.vagrantup.com/ealvarenga/boxes/TrueNAS-SCALE
v22.02.2.1 currently released version
This version was created about 2 years ago.
What’s the best way to try+test TrueNAS without buying expensive NAS hardware?
As it installs on pretty much anything x86, a vm or old hardware should work.
If it’s a matter of “see the UI,” the docs really should handle that without your needing to install it at all. If you want to play around in the UI, installing it in a VM (VirtualBox will work fine for this purpose) is probably the best answer. Keep in mind that 24.10 is due out next month, and is said to have some pretty significant changes to the UI.
