Here is the error that I got when upgrading my TrueNAS Scale software:
Error: Traceback (most recent call last): File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 515, in run await self.future File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 560, in __run_body rv = await self.method(*args) ^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 174, in nf return await func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/middlewared/plugins/update.py”, line 287, in update await self.middleware.call(‘update.install’, job, os.path.join(location, ‘update.sqsh’), options) File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1000, in call return await self.call( ^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 726, in call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 619, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/update/install_linux.py", line 50, in install self.middleware.call_sync(“update.install_scale”, mounted, progress_callback, options) File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1036, in call_sync return methodobj(*prepared_call.args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/update/install.py", line 41, in install_scale raise CallError(f"Checksum mismatch for {file!r}: {our_checksum} != {checksum}") middlewared.service_exception.CallError: [EFAULT] Checksum mismatch for ‘rootfs.squashfs’: 5b265c96157904a09332ee3c0b6c087489b0873c57c06b31463eb4da257ca216 != 8e334119203a1f7a03d633458c59bf025ce83440
How do I fix the above error or is there a fix for this?
