There seems to be a few issues with my upgrade. I have to Unset my Pool under Applications and Reset to get the Apps to show up.
nvidia-smi is not found
Install NVIDIA Drivers under Applications results in the following:
[EFAULT] Command apt update failed (code 1): Package management tools are disabled on TrueNAS appliances. Attempting to update SCALE with apt or methods other than the SCALE web interface can result in a nonfunctional system.
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 488, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 535, in __run_body
rv = await self.middleware.run_in_thread(self.method, *args)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1364, in run_in_thread
return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1361, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/nvidia.py", line 56, in install
with self._install_packages(
File "/usr/lib/python3.11/contextlib.py", line 137, in __enter__
return next(self.gen)
File "/usr/lib/python3/dist-packages/middlewared/plugins/nvidia.py", line 89, in _install_packages
subprocess.run(["apt", "update"], **kwargs)
File "/usr/lib/python3.11/subprocess.py", line 571, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['apt', 'update']' returned non-zero exit status 1.
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 533, in __run_body
rv = await self.method(*args)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 49, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 179, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/docker/update.py", line 106, in do_update
await (
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 436, in wait
raise self.exc_info[1]
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 492, in run
raise handled
middlewared.service_exception.CallError: [EFAULT] Command apt update failed (code 1):
Any help would be appreciated.
