Trouble finishing HTTPS on TrueNAS
I’m trying to access my TrueNAS interface via HTTPS instead of HTTP. I’m running TrueNAS 25.10.2.1 - Goldeye
I have purchased a domain for a different purpose and would like to use it to generate SSL certs for my TrueNAS interface
I created a cloudflare account and added the domain to it.
I’ve generated certs and tried installing those into TrueNAS via the API token.
I’ve tried a few different tutorials but their advice/instructions haven’t resolved the issue.
Eventually I would like to access the TrueNAS interface via a subdomain (nas.my domain), potentially restricting access to that subdomain it to connections on the same LAN.
I’ve installed adguard and nginix proxy manager onto TrueNAS while following tutorials but nothing has fully worked.
Does anyone have a modern or comprehensive tutorial? Otherwise, what configs of mine do you need to diagnose or advise what I did wrong?
Thanks.
I feel like I’ve gotten 60% of the way on a few different guides before my system/results stop matching what the guide expects.
If what you want to do is get a cert for your NAS and renew it automatically, see:
If you instead want to put your NAS behind NPM as a reverse proxy, see:
