TrueCloud Backup stuck at 0%
I recently upgraded to ElectricEel-24.10.0.2 and configured TrueCloud Backup with Storj.
Given that there is 2 TB to backup, I figured it would take many hours for the first backup to complete, but instead what I’m seeing doesn’t give me confidence in TrueCloud Backup.
The task is running but is perpetually stuck on “Starting” at 0%.
When I view the Storj dashboard I see that 250.03 GB has been uploaded but this is after several days.
I’ve tried aborting and restarting the task. It never gets past “Starting 0.00%”.
Here’s the task configuration:
Schedule
Task Name: Backup Daily to Storj
Frequency: At 00:00, every day
Schedule: 0 0 * * *
Details
Path: /mnt/archive
Credentials: Storj truenas
Bucket: truenas-backup
Folder: /
Keep Last: 5
Transfers: -
Post Script: -
Pre Script: -
Excluded Paths
/mnt/archive/app_data
/mnt/archive/ix-applications
Snapshots
No records have been added yet
I’ve been using TrueNAS and FreeNAS before it for a decade and would really like to have a simple, reliable cloud backup solution in case my unit at home fails. I was previously using Duplicacy in a jail but was hoping TrueCloud Backup would be simpler to maintain and operate.
I’d greatly appreciate any guidance / tips to get this working. Or if TrueCloud Backup is still not ready for prime time, it would be great to know that as well.
Thanks,
Frank
These tasks process percentages were never great.
I would stop the process and then see what the logs show you.
Then storj is definitely not for you.
Storj is a at best a beta S3 provider with added layers of complexity. Basically it is a centralized S3 with a wonky decentralized storage backend that hopes someday we will use the native integration, but weren’t even able to convince or provide a native integration for their partner ixSystems. If you ever wondered why the TrueNAS downloads and updates are so slow, it is because TrueNAS uses storj as their mirror.
There is also a in my opinion high risk of them running out of venture capital money.
So what I would recommend you instead is someone like Backblaze. They know what they are doing and it just works. Also there are only a little bit more expensive than storj.
@Sara Appreciate the suggestion to use Backblaze. I had previously was using Backblaze for several years using Duplicacy running in a jail.
What’s your preferred way to backup to Backblaze with a TrueNAS Scale system? Does it support incremental backups or is it just a simple sync?
I migrated to OneDrive (not working anymore, API calls are too limited) and I am currently migrating again to sync data to another TrueNAS.
I am still on CORE. I used a simple could sync task to Backblaze. They offer object lock and lifecycle rules for ransomware protection, but I am not sure if TrueNAS supports that. I know that Synology Hybrid Backup can’t handle object lock.
I am going to try setting up the backrest GUI in a Docker container, which uses restic under the hood. The goal would be to backup to Backblaze B2.
