TrueNAS-13.0-U6.2 Driver Offline
TrueNAS-13.0-U6.2
Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
15.6GiB
2 Western Digital Nas Driver as Raid
1 Normal Drive
1 Normal Drive
Hello everyone,
I hope you can help me. I’m not very familiar with TrueNAS. I set up a server back then, and it has been running very well until now. Suddenly, my hard drives appear as “Offline” on the dashboard. What could be the reason for this? Is it possible to bring them back online?
Hi, hard to express an opinion… something Is sure going very wrong in your system, and i think there are some bad choice that i hope you will not regret now (stripe pools and SMR disks)…
Can you share a zpool status and a disk list?
Why are you running RAID on ZFS?
The zpool status output Is complete? There Is only the boot pool.
If you can don’t use the GUI Shell, with Putty or similar copy the output and paste here including double `.
A camcontrol devlist output can be usefull too
root@freenas[~]#  zpool status
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0B in 00:00:27 with 0 errors on Fri Sep 27 03:45:27 2024
        NAME          STATE     READ WRITE CKSUM
        freenas-boot  ONLINE       0     0     0
          da0p2       ONLINE       0     0     0
errors: No known data errors
root@freenas[~]# camcontrol devlist
<WDC WD40EFRX-68WT0N0 82.00A82>    at scbus0 target 0 lun 0 (pass3,ada2)
<WDC WD40EFRX-68WT0N0 82.00A82>    at scbus1 target 0 lun 0 (pass2,ada1)
<WDC WD40EFAX-68JH4N0 82.00A82>    at scbus3 target 0 lun 0 (pass1,ada0)
<ASMT 2115 0>                      at scbus4 target 0 lun 0 (da0,pass0)
Honestly, seems like your pools has been disconnected, with your disks now no party of a pools.
The risk to worsening the situation Is high, so meanwhile check disk status and let’s see if someone Is fail or if the mainboard controller have had a critical issue: smartctl -a /dev/ and add adaX for each disks you have.
Check if via GUI you can import One of those pools
What does this mean?
Are you implying these are two drives (directly connected to SATA ports on your motherboard) that are configured into a mirror vdev?
You’re not suggesting that they are plugged into a “hardware RAID controller”?
Yes, the two drives are connected as RAID to the motherboard, not to a RAID controller.
What does that mean?
You configured them as “RAID” in a motherboard/BIOS setting?
Many users in the forums tend to mix up the terms “RAID” with a mirror or RAIDZ vdev (i.e, ZFS “RAID”).
root@freenas[~]# smartctl -a /dev/ada0
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build)
Model Family:     Western Digital Red (SMR)
Device Model:     WDC WD40EFAX-68JH4N0
Serial Number:    WD-WX52D104LK9S
LU WWN Device Id: 5 0014ee 2bcffce48
Firmware Version: 82.00A82
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
TRIM Command:     Available, deterministic, zeroed
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Sep 30 15:58:34 2024 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (14580) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off supp        ort.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (  33) minutes.
Conveyance self-test routine
SCT capabilities:              (0x3039) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_        FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -        0
  3 Spin_Up_Time            0x0027   217   199   021    Pre-fail  Always       -        2141
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -        994
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -        0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -        0
  9 Power_On_Hours          0x0032   074   074   000    Old_age   Always       -        19246
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -        0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -        0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -        973
192 Power-Off_Retract_Count 0x0032   199   199   000    Old_age   Always       -        893
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -        239
194 Temperature_Celsius     0x0022   109   094   000    Old_age   Always       -        38
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -        0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -        0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -        0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -        0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -        0
SMART Error Log Version: 1
ATA Error Count: 215 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 215 occurred at disk power-on lifetime: 19243 hours (801 days + 19 hours)
  When the command that caused the error occurred, the device was active or idle        .
  ER ST SC SN CL CH DH
  04 61 01 00 00 00 40  Device Fault; Error: ABRT 1 sectors at LBA = 0x00000000        = 0
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  c8 00 01 00 00 00 40 08      00:04:47.440  READ DMA
  c8 00 01 00 00 00 40 08      00:04:47.410  READ DMA
  c8 00 01 00 00 00 40 08      00:04:47.380  READ DMA
  c8 00 01 00 00 00 40 08      00:04:47.349  READ DMA
  c8 00 01 00 00 00 40 08      00:04:47.319  READ DMA
Error 214 occurred at disk power-on lifetime: 19243 hours (801 days + 19 hours)
  ef 02 00 00 00 00 40 08      00:04:47.319  SET FEATURES [Enable write cache]
Error 213 occurred at disk power-on lifetime: 19243 hours (801 days + 19 hours)
  ef aa 00 00 00 00 40 08      00:04:47.318  SET FEATURES [Enable read look-ahea        d]
Error 212 occurred at disk power-on lifetime: 19243 hours (801 days + 19 hours)
  c6 00 10 00 00 00 40 08      00:04:47.317  SET MULTIPLE MODE
Error 211 occurred at disk power-on lifetime: 19243 hours (801 days + 19 hours)
  ef 10 02 00 00 00 40 08      00:04:47.317  SET FEATURES [Enable SATA feature]
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA        _of_first_error
# 1  Extended offline    Completed without error       00%     19246         -
This kind of drives (WD40EFAX) are SMR and as such not good choice for NAS environment. Replace them with CMR Red drives (WD40EFRX) or even better with Red Plus ones (WD40EFPX, WD40EFZX).
I cant import the Pools. There is only the option Export or Disconnect.
Please, use the triple ` when you past content, or is not even readable.
Copyright (C) 2002-20, Bruce Allen, Christian Franke, [www.smartmontools.org](http://www.smartmontools.org/)
was never started.
been run.
command.
power-saving mode.
SS=sec, and sss=millisec. It “wraps” after 49.710 days.
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
The disk not seems faulting itself, but a lot of error has been threwed… i think GODwinni point in the right direction, you shuldn’t use hw RAID on TN, but honestly i don’t know how help you there sorry
Thank you.
Do you know how i can recover the Files in the Drives?
First, try to fully answer @winnielinnie 's questions: What do you mean by “as Raid”? How was the pool configured?
The pool name “RAID” is irrelevant.
There are two drives in there, one of which has had errors (=> replacement). This should not make a ZFS mirror pool unavailable, but would be deadly for a ZFS stripe.
Or, worse still, you had configured the drives as RAID0 on the board’s controller and used that as another single “drive” pool of 8 TB. If you mean THAT we want to know! (And if it was plain AHCI, we’d like confirmation too.)
If this was a non-redundant pool, your only hope is Klennet ZFS Recovery. Preferably running on this very motherboard if you had a hardware RAID setup because then the controller is part of the problem.
Output of zpool import please?
Also, suggested readings: Terminology and Abbreviations Primer | TrueNAS Community, Introduction to ZFS | TrueNAS Community, iX's ZFS Pool Layout White Paper, What's all the noise about HBAs, and why can't I use a RAID controller? | TrueNAS Community.
Thank you for the quick reply.
As far as I can remember, I had set up the RAID pool so that the two hard drives mirrored each other.
