TrueNAS-13.0-U6.2 Driver Offline
That’s OK. The question is how you did this.
Did you create a pool with two mirrored disks (that’s the recommended way) ?
Actually, the term “RAID” refers to various combinations of organizing hard disks, not necessary mirror. TrueNAS is using ZFS filesystem that is superior to hardware RAID controllers, so TN users should use the advantage of ZFS rather than traditional hardware RAID.
I assume that “RAID” is just the name for your pool. If so, “Mirror” would be better name, or even better something like “data-pool”, “VM-pool” or “backup-pool”.
that’s right. I named the pool “RAID”.
I created a pool with two mirrored disks.
Will change the name to the names you mentioned.
Thanks for the tip.
  pool: RAID
  state: ONLINE
status: Some supported features are not enabled on the pool.
        (Note that they may be intentionally disabled if the
        'compatibility' property is set.)
 action: The pool can be imported using its name or numeric identifier, though
        some features will not be available without an explicit 'zpool upgrade'.
        RAID                                            ONLINE
          mirror-0                                      ONLINE
            gptid/335f7a86-4d52-11eb-b8f2-a8a159073850  ONLINE
            gptid/338072d7-4d52-11eb-b8f2-a8a159073850  ONLINE
Please run zpool import RAID.
zpool import -o altroot=/mnt RAID
root@freenas[~]# zpool import -o altroot=/mnt RAID
cannot import 'RAID': I/O error
        Recovery is possible, but will result in some data loss.
        Returning the pool to its state as of Mon Sep 30 09:06:03 2024
        should correct the problem.  Approximately 68 seconds of data
        must be discarded, irreversibly.  Recovery can be attempted
        by executing 'zpool import -F RAID'.  A scrub of the pool
        is strongly recommended after recovery.
Run this.
Perhaps with a dry-run first? Just to play it safe?
zpool import -Fn -R /mnt RAID
Hello everyone,
I now have the following status in the dashboard.
And then?
zpool status -v to investigate this warning sign…
root@freenas[~]# zpool status -v
  pool: RAID
 state: ONLINE
  scan: resilvered 900K in 00:00:08 with 0 errors on Sat Oct  5 11:31:32 2024
        NAME                                            STATE     READ WRITE CKS        UM
        RAID                                            ONLINE       0     0        0
          mirror-0                                      ONLINE      24     0        0
            gptid/335f7a86-4d52-11eb-b8f2-a8a159073850  ONLINE       0     0        0
            gptid/338072d7-4d52-11eb-b8f2-a8a159073850  ONLINE       0     0        0
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0B in 00:00:30 with 0 errors on Fri Oct  4 03:45:30 2024
        NAME          STATE     READ WRITE CKSUM
        freenas-boot  ONLINE       0     0     0
          da0p2       ONLINE       0     0     0
Good. Scrub the pool, and if no errors are detected you might clear the warning.
With zpool clear RAID.
Thank you very much.
Can i usw the same Procedure for the two other Pools WD10WDC and WD40WDC?
You can certainly try.
Iget these Message for the Import
root@freenas[~]# zpool import WD10WDC
cannot import 'WD10WDC': no such pool available
root@freenas[~]# zpool import -o altroot=/mnt WD10WDC
root@freenas[~]#
You have three drives and three pools, and the RAID pool uses two drives: something is missing.
Are you able to import the WD40WDC pool?
I suspect you used the drive of WD10WDC to create the RAID pool: if this happened, you cannot recover that pool.
Do you confirm you have a total of 4 HDDs connected? Check the connections (both data and power).
camcontrol devlist
or gpart list for more details
root@freenas[~]# camcontrol devlist
<WDC WD40EFRX-68WT0N0 82.00A82>    at scbus0 target 0 lun 0 (pass2,ada2)
<WDC WD40EFRX-68WT0N0 82.00A82>    at scbus1 target 0 lun 0 (pass3,ada1)
<WDC WD40EFAX-68JH4N0 82.00A82>    at scbus3 target 0 lun 0 (pass1,ada0)
<ASMT 2115 0>                      at scbus4 target 0 lun 0 (da0,pass0)
root@freenas[~]# gpart list
Geom name: da0
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 62533255
first: 40
entries: 128
scheme: GPT
Providers:
1. Name: da0p1
   Mediasize: 272629760 (260M)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 20480
   Mode: r0w0e0
   efimedia: HD(1,GPT,a9545fd5-fdc3-11ea-aa53-a8a159073850,0x28,0x82000)
   rawuuid: a9545fd5-fdc3-11ea-aa53-a8a159073850
   rawtype: c12a7328-f81f-11d2-ba4b-00a0c93ec93b
   label: (null)
   length: 272629760
   offset: 20480
   type: efi
   index: 1
   end: 532519
   start: 40
2. Name: da0p2
   Mediasize: 31742492672 (30G)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 272650240
   Mode: r1w1e1
   efimedia: HD(2,GPT,a9772928-fdc3-11ea-aa53-a8a159073850,0x82028,0x3b20000)
   rawuuid: a9772928-fdc3-11ea-aa53-a8a159073850
   rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 31742492672
   offset: 272650240
   type: freebsd-zfs
   index: 2
   end: 62529575
   start: 532520
Consumers:
1. Name: da0
   Mediasize: 32017047552 (30G)
   Sectorsize: 512
   Mode: r1w1e2
Geom name: ada2
wither: (null)
Providers:
1. Name: ada2p2
   Mediasize: 3998639460352 (3.6T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   wither: (null)
Consumers:
1. Name: ada2
   Mediasize: 4000787030016 (3.6T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e3
Geom name: ada1
wither: (null)
Providers:
1. Name: ada1p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   wither: (null)
Consumers:
1. Name: ada1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e3
