TrueNas 24.04.1.1 Scale stuck after selecting in Grub
Good afternoon. We have a 4 bay TrueNas. All was working fine until two days ago. Then we noticed the network adapters were not online. Upon rebooting the system, they stayed down. I put a monitor on the TrueNas to see that once selecting TrueNas 24.04.1.1 in Grub, it starts to load then hangs on the screen below. I have tried to select 24.4.0 neither of the OS load. 24.4.0 gives an error that Kernel panic not syncing. Is there a way to recover from this? I would like to try and recover the config files so that I can reload the OS and recover my zpool and the data in it. Below is what is showing on the screen after selecting 24.04.1.1. Any ideas?
Thank you for you help.
Brian
txg_wait_synced+0x10/0x40 [zfs]
xy_wall_synctu_imp
1209.461269]
1289.462852]
1289.462845]
spa_load_impl.constprop.0+0x36a/0x520 [zfs] spa_load+0x73/0x120 [zfs]
1289.4636731 spa_load_best+0x54/0x250 [zfs]
1289.464469]
spa_import+0x231/0x680 [zfs]
1209.4652641] zfs_ioc_pool_import+0x15b/0x180 [zfs]
1209.466036]
zfsdev_ioctl_common+0x680/0x798 [zfs]
1209.4668071 ? __kmalloc_node+0xc6/0x150
1209.4669291
1209.467787]
1209.467829]
1209.467946]
zfsdev_ioct1+0x53/0xe0 [zfs]
___x64_sys_ioctl+8x97/0xd0
do_syscall_64+0x59/0xb0
entry_SYSCALL_64_after_hwframe+0x78/0xe2
1209.468064] RIP: 0033:0x7fe298f91c5b
1209.4681791 RSP: 002b:00007ffd673fe400 EFLAGS: 00000246 ORIG_RAX: 00000000000
10010
1209.468321] RAX: ff f f f f f f f f f fffda RBX: 0000000000000000 RCX: 00007fe298f91c5b 1209.468440] RDX: 00007ffd673fe4c0 RSI: 0000000000005a02 RDI: 0000000000000003 1209.468559] RBP: 00007ffd67402360 R08: 00007fe299067390 R09: 00007fe299067390 1209.468678] R10: 0000000000000000 R11: 0000000000000246 R12: 0000561fc8b242c0 1209.468797] R13: 00007ffd673fe4c0 R14: 00007fe28c0017e8 R15: 0000561fc8b44720 1209.468918]
1209.4690251 Future hung task reports are suppressed, see sysctl kernel.hung_t sk_warnings
Esc
F1
F2
F3
F4
F5
F6
F7
F8
LG
It seems likely to be a boot drive issue.
Can you test with only boot drive installed or replace with another boot drive?
