TrueNAS CE - cronyd could not add source
I am puzzled on an issue with TN CE. I am running an NTP server on pfSense that works fine with all devices on my LAN. I do however have a repeating log entry for TN CE:
24-07-2025 18:43 Error truenas-e3-1220.local daemon chronyd Could not add source 192.168.1.1
The strange part is, if i check all seems fine:
Last login: Thu Jul 24 19:13:27 CEST 2025 on pts/1
root@truenas-e3-1220[~]# timedatectl status
               Local time: Thu 2025-07-24 19:15:49 CEST
           Universal time: Thu 2025-07-24 17:15:49 UTC
                 RTC time: Thu 2025-07-24 17:15:49
                Time zone: Europe/Brussels (CEST, +0200)
System clock synchronized: yes
              NTP service: active
          RTC in local TZ: no
Any ideas where this comes from?
Can you verify the IP addressing of each device?
Do you have connectivity via ping and ssh?
Yes i do. Ping works fine and i can also login via SSH. I also checked and everything seems fine.
root@truenas-e3-1220[~]# chronyc sources
MS Name/IP address         Stratum Poll Reach LastRx Last sample
^? D1521-pfSense.lan             3   6     1    48    -12us[  -12us] +/-   34ms
I just don’t understand why this causes an error in my logs
Update to 25.04.2 when you are comfortable… if problem persists, then report-a-bug.
