TrueNAS incorrectly pulls rotation speed of a virtual disk under VMWare Workstation
In the WebUI, as well as when running midclt call disk.query | jq, one of the virtual disks passed to TrueNAS Scale under VMWare Workstation shows rotation speed of 15K:
    "identifier": "{serial_lunid}6000c29da1ec0401b00a68b305c6b183_6000c29da1ec0401",
    "name": "sdb",
    "subsystem": "scsi",
    "number": 2064,
    "serial": "6000c29da1ec0401b00a68b305c6b183",
    "lunid": "6000c29da1ec0401",
    "size": 21474836480,
    "description": "",
    "transfermode": "Auto",
    "hddstandby": "ALWAYS ON",
    "advpowermgmt": "DISABLED",
    "expiretime": null,
    "model": "VMware_Virtual_S",
    "rotationrate": 15000,
    "type": "HDD",
    "zfs_guid": "8844258940006280448",
    "bus": "SCSI",
    "devname": "sdb",
    "enclosure": null,
    "pool": null
This appears to happen on one of 7 SCSI virtual disks. Other disks correctly show null for rotation rate:
    "identifier": "{serial_lunid}6000c295f164cd044218b634749f2918_6000c295f164cd04",
    "name": "sdd",
    "number": 2096,
    "serial": "6000c295f164cd044218b634749f2918",
    "lunid": "6000c295f164cd04",
    "description": "",
    "expiretime": null,
    "rotationrate": null,
    "type": "HDD",
    "zfs_guid": "10183660113133072398",
    "bus": "SCSI",
    "devname": "sdd",
    "enclosure": null,
    "pool": null
Oddly, the output of smartctl shows rotation rate too:
truenas_admin@truenas[~]$ sudo smartctl -a /dev/sdb
[sudo] password for truenas_admin:
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.12.33-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor:               VMware,
Product:              VMware Virtual S
Revision:             1.0
User Capacity:        21,474,836,480 bytes [21.4 GB]
Logical block size:   512 bytes
Rotation Rate:        15000 rpm
Logical Unit id:      0x6000c29da1ec0401b00a68b305c6b183
Serial number:        6000c29da1ec0401b00a68b305c6b183
Device type:          disk
Local Time is:        Mon Mar 23 09:55:19 2026 PDT
SMART support is:     Unavailable - device lacks SMART capability.
Current Drive Temperature:     0 C
Drive Trip Temperature:        0 C
Error Counter logging not supported
Device does not support Self Test logging
Is this a bug in VMWare Workstation, a bug in TN, a bug upstream, or a skill issue? I have never encountered this behavior in the past.
Virtual devices have nothing to do with the actual hardware that is underneath. Its an emulation.
You can emulate 12 cpu cores on a 4 core CPU.
That beeing said, if you value your data, dont use virtual devices for Truenas ( other than the boot device). As for the hypervisor. Proxmox and esxi can be made to work reliably ( with caveats). But yours is IMO a type 2 hypervisor and these are not recommended at all.
I used ESXi v7 and v8 to run FreeNAS, TrueNAS Core, and TrueNAS Scale without any issues at all. I don’t recall but I thought you could tell the emulation the RPM and other values in ESXi, but I no longer use ESXi at the time. I may go back to it, not sure. I’m giving Scale on bare metal a try for at least 1 year, less if I run into problems.
I am trying to evaluate TN in VMWare Workstation. I think that it’s a fair use case. While I do have the hardware to test TN on, some configurations/tests are simply easier and quicker to run in a VM.
Thats perfectly fine.
Update: I booted into Parted Magic and it too shows the 15K rotation speed for one of the virtual disks. I am going to investigate this outside TN. Thanks everyone for your input.
It’s possible that the device isn’t set with having “SSD Emulation” enabled in either the .vmx or .vmdk descriptors for it specifically, and the others are.
The weird thing is that all the virtual disks were created exactly the same way through the Workstation GUI. I am going to have a dig in the .vmx first.
Love to hear the results
I took a look and I did not see anything unusual in the vmx file.
