TrueNAS instance can no longer connect to external web
When trying to add a new container, I noticed that I can no longer see available containers in the “Discover Apps” section. I also cannot pull containers via the command line or Dockge, as I tried that with Docker’s Hello World sample container.
Logs from FreshRSS also say that it keeps timing out, but this must be new, as I have posts from yesterday in my feed.
The only thing I changed between yesterday and today was removing some old containers in Dockge from when I tried setting up Traefik, but they were all already inactive when I removed them, so I don’t know how that could affect it.
Other than that, network-wise I only have Tailscale, but that seems to be working, as I am using it to connect to the Web UI.
I’ve restarted my NAS, just to see if maybe the Traefik container did something funky despite being down, but as expected, it did not help. For some reason I can see the apps now, but once more, it times out when trying to pull any images and FreshRSS can’t update my feeds either.
I foolishly tried to update my containers, but of course that did not work, as it can’t pull the new images.
I also tried to check if it’s a DNS issue, but pinging 8.8.8.8 also doesn’t work, so that doesn’t seem to be it.
Other devices in my network can connect to the web, so I don’t think it’s a router issue either.
I do not know how to diagnose this further, so I’d appreciate any advice.
After some further diagnosis and turning things on an off, the issue seems to have been Tailscale. The exit node I’ve been using was no longer available, so I simply had to change it and it works again. Whoops.
