TrueNAS Scale 25.04.1 install problem on new system (NIC related)
Hey all, I’m replacing an old underpowered QNAP NAS with a new build and I’m trying to get TrueNAS Scale installed and working on it but I’m running into problems. I got the installer USB to boot and do the initial installation and set the admin password, but when I remove the media and reboot my NIC isn’t being detected at all - which won’t let me continue the installation b/c it can’t fire up/access the web interface. It’s a Realtek NIC w/ the 8125 chipset built into the motherboard. I’ve seen a bunch of posts about this situation, but all the fixes seem to be BSD/Core-specific and involve editing a config file to point to the r8125.ko driver, which doesn’t exist on the Scale filesystem. I even tried building the driver on another host and copying it over, but the filesystem is readonly at this point of the install. Any help/suggestions (outside of buy a new NIC) would be greatly appreciated.
System specs:
ASUS Prime Z890M PLUS WIFI motherboard
Intel Core Ultra 265K CPU
64GB RAM
2x NVME SSDs
6x 18GB HDDs
Thanks!
Update: FWIW I think I’ve spotted the problem. It looks like the installer tries to load a realtek driver, but then throws an error saying that the driver doesn’t recognize the chip in the NIC and fails. I suspect it’s b/c this is built using an older driver. Curious if there are any plans to update drivers in future builds, or what the feasibility is of cloning the scale-build repo and including the drivers myself to build an installer ISO that has the latest drivers?
Thanks again!
Any chance you figured it out? I’m in the same spot with the exact same board.
Sadly no. I ended up having to buy a junk NIC from Amazon and waste a PCI slot. :frowning: Everything I’ve read seems to indicate that the maintainers avoid updating drivers as much as they can b/c of “stability” and then use the same excuse for configuring everything in a filesystem that’s read-only. Probably makes sense from a commercial standpoint, but annoying when you’re just setting it up for home use and willing to do some tinkering/experimenting - but can’t.
