I’ve 3 Samsung 870 EVO 1 TB RAIDZ-1 with all failed SMART-Tests. They only have 7000h and 1,6TBW usage. Can that be true?
1st:
SMART Attributes Data Structure revision number: 1
5 Reallocated_Sector_Ct 0x0033 098 098 010 Pre-fail Always - 16
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 7783
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 65
177 Wear_Leveling_Count 0x0013 099 099 000 Pre-fail Always - 9
179 Used_Rsvd_Blk_Cnt_Tot 0x0013 098 098 010 Pre-fail Always - 16
181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0
182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0
183 Runtime_Bad_Block 0x0013 098 098 010 Pre-fail Always - 16
187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0032 066 057 000 Old_age Always - 34
195 ECC_Error_Rate 0x001a 200 200 000 Old_age Always - 0
199 CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0
235 POR_Recovery_Count 0x0012 099 099 000 Old_age Always - 19
241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 14205300540
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 7770 -
# 2 Extended offline Completed: read failure 60% 7770 1195560416
# 3 Extended offline Completed: read failure 60% 7718 1195560416
# 4 Short offline Completed without error 00% 7602 -
# 5 Short offline Completed without error 00% 7434 -
# 6 Short offline Completed without error 00% 7266 -
# 7 Short offline Completed without error 00% 7098 -
# 8 Extended offline Completed: read failure 60% 7098 1161688656
# 9 Extended offline Completed: read failure 60% 6974 1161688656
#10 Short offline Completed without error 00% 6930 -
#11 Short offline Completed without error 00% 6762 -
#12 Short offline Completed without error 00% 6594 -
#13 Short offline Completed without error 00% 6426 -
#14 Short offline Completed without error 00% 6258 -
#15 Extended offline Completed: read failure 60% 6258 1161688656
#16 Extended offline Completed: read failure 60% 6253 1161688656
#17 Short offline Completed without error 00% 6090 -
#18 Short offline Completed without error 00% 5922 -
#19 Short offline Completed without error 00% 5754 -
#20 Short offline Completed without error 00% 5586 -
#21 Extended offline Completed: read failure 60% 5586 1161688656
2nd:
5 Reallocated_Sector_Ct 0x0033 083 083 010 Pre-fail Always - 199
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 7580
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 82
177 Wear_Leveling_Count 0x0013 099 099 000 Pre-fail Always - 10
179 Used_Rsvd_Blk_Cnt_Tot 0x0013 083 083 010 Pre-fail Always - 199
183 Runtime_Bad_Block 0x0013 083 083 010 Pre-fail Always - 199
190 Airflow_Temperature_Cel 0x0032 067 059 000 Old_age Always - 33
235 POR_Recovery_Count 0x0012 099 099 000 Old_age Always - 33
241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 14188370558
No Errors Logged
# 1 Short offline Completed: read failure 60% 7578 33362280
# 2 Short offline Completed: read failure 60% 7577 33362312
# 3 Short offline Completed: read failure 60% 7568 33362312
# 4 Extended offline Completed: read failure 90% 7568 33362280
# 5 Extended offline Completed: read failure 90% 7515 33362280
# 6 Short offline Completed: read failure 50% 7515 33364288
# 7 Short offline Completed: read failure 50% 7400 33364288
# 8 Short offline Completed: read failure 50% 7400 33362280
# 9 Short offline Completed: read failure 50% 7232 33362280
#10 Short offline Completed without error 00% 7064 -
#11 Short offline Completed without error 00% 6896 -
#12 Extended offline Completed: read failure 90% 6895 312147696
#13 Extended offline Completed: read failure 90% 6771 312147696
#14 Short offline Completed without error 00% 6728 -
#15 Short offline Completed without error 00% 6560 -
#16 Short offline Completed without error 00% 6392 -
#17 Short offline Completed without error 00% 6223 -
#18 Short offline Completed: read failure 60% 6132 33364360
#19 Short offline Completed: read failure 60% 6055 33364360
#20 Extended offline Completed: read failure 90% 6055 110004744
#21 Extended offline Completed: read failure 90% 6050 110004744
3rd:
5 Reallocated_Sector_Ct 0x0033 094 094 010 Pre-fail Always - 58
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 84
179 Used_Rsvd_Blk_Cnt_Tot 0x0013 094 094 010 Pre-fail Always - 58
183 Runtime_Bad_Block 0x0013 094 094 010 Pre-fail Always - 58
190 Airflow_Temperature_Cel 0x0032 067 057 000 Old_age Always - 33
235 POR_Recovery_Count 0x0012 099 099 000 Old_age Always - 42
241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 14559786450
No Errors Logged
# 1 Short offline Completed without error 00% 7568 -
# 2 Extended offline Completed: read failure 70% 7568 984143200
# 3 Extended offline Completed: read failure 70% 7515 984143200
# 4 Short offline Completed without error 00% 7400 -
# 5 Short offline Completed without error 00% 7232 -
# 6 Short offline Completed without error 00% 7064 -
# 7 Short offline Completed without error 00% 6896 -
# 8 Extended offline Completed: read failure 70% 6896 984143200
# 9 Extended offline Completed: read failure 70% 6771 984143200
#10 Short offline Completed without error 00% 6728 -
#11 Short offline Completed without error 00% 6560 -
#12 Short offline Completed without error 00% 6392 -
#13 Short offline Completed without error 00% 6224 -
#14 Short offline Completed without error 00% 6055 -
#15 Extended offline Completed: read failure 70% 6055 984143200
#16 Extended offline Completed: read failure 70% 6051 984143200
#17 Short offline Completed without error 00% 5888 -
#18 Short offline Completed without error 00% 5720 -
#19 Short offline Completed without error 00% 5552 -
#20 Short offline Completed without error 00% 5384 -
#21 Extended offline Completed: read failure 70% 5384 984143200
Thank’s for your help
