Truenas scale not recognizing nvidia gpu 1070ti
Hi all,
First time poster. I have a 1070ti GPU i’d like to use for plex hardware transcoding. The PCI bus seems to detect it but truenase doesn’t seem to see it.
Running this command shows:
root@dnkserv[~]# lspci | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070 Ti] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
I cannot see the GPU in system/advanced/ isolate GPU and all of my apps have nvidia drivers installed. any advice?
please and thanks.
I got it working!.
by adding a deploy section and a few environment lines nvidia
Can you provide more context to how you solved this issue? I am running into the same thing right now with my setup.
