Thanks for this, I think you deserve a little recognition for this. Script looks great, instructions clear and my tests seem all fine. Appreciated for this solution which will survive OS updates and reboots.
Thank you, Thank you, Thank you. This is extremely useful. I had a high pitched whine coming from my NAS and had read about different things to try, tried this script and the whine stopped so I now know it’s the cooling fan I eventually need to replace, but to be honest as the fan is spinning a little quicker now the whine has stopped so I won’t bother replacing it.
Please send details on how I can buy you a coffee to say thanks.
I haven’t looked through the script in detail but how are you getting around the fact that there is no 8613E support in the kernel? Is this the same as the other methods where you load a similar driver like the 8622?
Edit: ok I’ve just tested it and it just loads the 8622 driver. An alternative to this script is just loading the 8622 driver manually with sudo modprobe it87 force_id=0x8622 and then using something like CoolerControl, which has a nice GUI. Same functionality but one less script.
Does anyone else have an issue with the 8622 driver where the CPU fan RPM isn’t reported?
