Those who have seen me post before know that I only recently started deploying a TrueNAS system. Thanks @stk !
I now have a USB cable connected between my UPS and the TrueNAS. I find the unit of “Days” on the UPS Runtime in Reporting → UPS not that useful. How long is “0.03 days” in minutes or seconds? It would be great, if a future revision of the software would allow me to configure the units on the y-axis of that graph and switch between Days, Hours, Minutes, Seconds.
I wish, I had a UPS large enough, where Days would make sense. But then my power outages are rare and, when they do occur, usually do not last longer than a couple of hours.
Do not depend on the developers following the forums.
You can submit bug reports and suggestions under Report a Bug. This is the best way to report something. I already reported this issue, but if you see any other problems or recommendations, please submit a ticket.
Just used it yesterday to suggest that there be a drive burn-in task that would show up on the Jobs pull-down. It would be much more convenient than running a shell script with tmux that does that.
I am using such a script to burn in the 12-TB drives from your NAS write-up.
I found multiple Jira reports relating to the “runtime in days” issue (links below), and the suggestion from Jira is to create a feature request on the forum. However after a brief search I couldn’t find anything relevant in the specified sub-forum, so I’m guessing nobody has created one (yet)?
