I have a HP Proliant Microserver N36L currently running FreeNAS 11.0-U4
I want to update FreeNAS, either to the latest TrueNAS core or to whatever would be
best for my hardware.
Have a few questions/concerns…
1.) What upgrade path should I take?
11 → 11.2 → 11.3 ->12 ->12.1 ->…-> 13
Or
11.0 → 11.3 → TrueNAS
Also, the first few updates I would need to manually do as 11.0 is not detecting any updates anymore, not linking to the correct download/update repository
Is there anyone that can step me through which versions to install.
2.) I used to have a Jail with a plex server running on it (its still all there but for some reason I can’t get to the plex server anymore from a web browser), I know that in 11.2 FreeNAS started moving away from Warden to IOCage and I read that there are scripts or ways to convert the jails
Question is, with my older version of FreeNAS should I try recover my Jail and Plex server… or just start from scratch?
Very Simple setup…
Updated Bios to allow 5th drive
4x 3TB drives, 1x 6TB Drive, 1x SSD (OS)
Basic file share so 1 volume RaidZ2, running SMB
no encryption (nothing on it is sensitive information)
Then as an addition, a jail running Plex.
I don’t mind the long upgrade path if it gets me to the right destination, I just need to know WHICH versions I am installing. (and where to grab them)
I’m going to probably need help with rebuilding the Plex app and importing.
otherwise… if need be, will have to scrap and start fresh on that front
As opposed to self-maintained jails.
Plugins are no longer maintained (possibly never were…), and if they are half-dead I’m unsure what the half-living part is.
i guess some clarification is needed here: iX announced that in time, they will abandon TrueNAS Core (you have FreeNAS which is basically now TrueNAS Core) and put all their money on TrueNAS Scale. The big difference is Core is based on FreeBSD and Scale is based on Linux.
For Core, you would be able just to upgrade to the latest level upgrading through every major release, as mentioned before. As far as i know, you might be able to save Plex by upgrading the jail with the iocage upgrade command but i am unsure if this is a reliable process. When it is stated, “don’t use plugins” this refers to Core as the original plugin section has been unmaintained for quite some time now. It would be better to use a script (like @dan 's scripts to get that done)
For Scale, you could migrate from Core to Scale through the GUI but bear in mind, your Plex instance (plugin or manual jail) will cease to run and would need to be set up from scratch in Scale.
It does clear some things up, but does not entirely help…
My FreeNAS GUI is not showing any update paths…so this is not going to help.
Why I asked what update path I should follow, then I was told to update through the major releases, I then asked what the major releases are, and there was no answer.
